Old 12-01-2012, 03:59 PM
FETorino's Avatar
FETorino FETorino is offline
Love that body style. What's the owner going with for a drivetrain?
Don't let Matt near it.
Rob in SoCal
Old 12-01-2012, 08:11 PM
kiwigt kiwigt is offline
Subscribing... I plan on using the DSE front and rear systems in my 66 GT fastback, so I'm really interested in seeing the installation detail.
Old 12-02-2012, 08:12 AM
GPR's Avatar
GPR GPR is offline
Not sure about the drivetrain yet and Matt hasn't seen it.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 12-02-2012, 08:29 AM
GPR's Avatar
GPR GPR is offline
There was a lot of bubbles and paint coming off so I decided to investigate before sending it to be blasted.
Rusty Gillis
Port Richey Fl
Old 12-02-2012, 07:16 PM
preston preston is offline
Ha you guys always seem to end up with projects that have to be done the hard way.
Old 12-04-2012, 06:22 AM
GPR's Avatar
GPR GPR is offline
We have repairs to do before we install the DSE mini tubbs.
The front crossmember had been hit so we replaced it
Before we installed the new one Brian cleaned up the surface rust than brushed a coat of SPI epoxy
The left front apron has a little rust so Brian cut it out
There was also a little rust on the firewall. After drilling out the spot welds on the fender apron Brian patched it.
Rusty Gillis
Port Richey Fl
Old 12-05-2012, 06:45 AM
GPR's Avatar
GPR GPR is offline
Both quarter panels need to be replaced.
After they were removed everything was epoxy primed
Lining up the new trunk floor
Rusty Gillis
Port Richey Fl
Old 12-05-2012, 08:02 AM
KPC67's Avatar
KPC67 KPC67 is offline
Off to a good start
Kevin Carter
