Old 12-09-2012, 06:42 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
There was a bit of a miscommunication on the wheels and they ended up not fitting the car. Rather than try to modify them they are going to make a new set.
I've been working on the front seat, integrating seat belts. The belt regulator and top mount/bezel are from an Escalade 3rd row seat and mounted in a similar fashion (belt exiting top of seat). I measured the distance on the Escalade seat from the seat bottom to the bezel and made pieces to mount these at the same height on the Brougham seat. Feels like it will be comfortable and the angle on the belt is minimal. (should be fine as it exactly duplicates the geometry of the stock cadillac seat).
Seat frame will be strengthened. Where the rearmost seat mounting holes are in the floor I'm going to add a body mount there to the frame.
Now I need to take the seat back frame and modify the structure to go around the seat belt assemblies. Over this will be a shaped piece of high density foam that will take place of the original springs. I'll have the plastic seat belt bezels duplicated in aluminum and chrome plated.
