Old 12-15-2012, 06:32 PM
Jr's Avatar
Jr Jr is offline
The heat management issues with turbos will be as big or probably a bigger problem than IAT's with a blower. I know Mark Stielow's latest car had very good IAT's in real world conditions.
Jody,
Marks setup has had hours of dyno testing to get it where it's at. Plus, the cost of a Thompson built motor vs a ls with a magnacharger on top is a night and day difference in performance, engineering, and IAT numbers
Old 12-15-2012, 07:05 PM
camcojb camcojb is online now
Originally Posted by DJW32 View Post
Jody,
I understand that. I would look at more than just air temps when picking a forced induction direction. They all have advantages and disadvantages.
Old 12-16-2012, 02:53 PM
gnx7's Avatar
gnx7 gnx7 is offline
Look up the gearing in that GTO transmission. It isn't the best for a turbo setup IMO. the 2.66 1st gear style '98-02 Fbody transmissions would be better or if you can afford it a new T56 Magnum which is 10x better in all ways.
A stock pre '05 engine has LS1 style rods which are good to around 550-600rwhp before they bend. With a perfect tune it will last.... but in the end the rods will bend. LS2 style rods seem to be good to around 800-900rwhp.
A stock intake and TB will meet your power goals easily. A single turbo would meet your goals easily but twins are aesthetically more pleasing... and more $.
If you don't plan to AutoX or Road race your car you probably don't really need the aluminum block. Crunching the numbers with the power you want... it may be best to sell that LS1 instead of building it up... and get an '05+ style engine.
Old 01-23-2013, 05:07 PM
TurboBu TurboBu is offline
6.0 truck heads, arp or eBay studs, ls9 gaskets, mid to upper 22x°@.050" 114° lsa cam with good springs and a pair of 5858 provisions. it' 'll have way more power than a roots and be just as responsive. PM 417 Motorsports on here it you decide to go turbo.
Old 06-23-2013, 08:35 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
You need to lower the compression to no higher than 8:1 . No higher otherwise you will have to run race gas.I would use a Blower/Turbocharger piston,with a strong bottom end. Good set of heads
Old 06-24-2013, 05:49 AM
8:1 compression is for dinosaur engines oe iron headed sbc and bbc with bad combustion chamber designs. LSX engine will be a slug on the bottom end like that
Old 06-27-2013, 10:30 AM
Zspoiler's Avatar
Excuse Me, I`m running a set of ported Eldelbrock Performer RPM Aluminum Cylinder heads.With 2:05 intake /1:60 Manley valves. And I run 15 lbs of boost. And I know a number of successful engine builders. 8:1 compression is the maximum compression.Unless you want to run alcohol or race gas.Other wise the pre ignition will kill the rings.
Old 06-28-2013, 01:39 PM
417 Motorsports's Avatar
417 Motorsports 417 Motorsports is offline
I'm sorry but you are a prime example of why the Internet is such a bad source for technical information. 8:1 compression was great in the early days of turbocharging but with today's technology it only makes fr a sluggish unresponsive "n/a" motor until the turbo is able to achieve positive pressure.
In today's modern day its not uncommon to see 9.5, 10, even 10.2:1 factory produced forced induction engines rinning on 91-93 octane pump gas. My personal car is 11:1 on pump fuel (e85) sees 24-25 psi with 24' of timing in boost and has been together making 4 digit rwhp numbers for 4 years currently with no issues.
Keep in mind sir, there's ALOT more to making a boosted motor happy then just compression
Cheers
Blake
Old 07-01-2013, 09:27 AM
2keaton11's Avatar
2keaton11 2keaton11 is offline
Smile TT's
Im also in the process of doing this, I picked up a kit that was designed for a SBC and im running an L92, it was all brand new and got everything complete for to cheap I felt. I hear the compression from a L92 is lower than a typical LS3, is this true? Useful information from a lot of smart guys on here. Who builds a nice set of Turbo Headers, I heard OBX from John 510 and Is there anyone in Oklahoma who can help set it up? I think I would like to finish the car and drive it before I blow the motor up but no problem in having the info advance and going ahead and placing the orders.
Old 10-31-2013, 05:06 PM
I'm in southwest mo
