Old 01-06-2013, 12:08 AM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default Aeromotive Pump fell apart; help needed....
I have an Aeromotive Stealth 340 fuel pump. When I was mocking it up the silver ring popped off the outlet an a couple parts fell out. There is a little copper "plunger" and a white plastic sleeve that came out. Unfortunately Im not sure how they go back in. From what I cant tell the copper plunger thing fits into the white sleeve, but I dont know which way it goes. Any info on how this goes back together would be greatly appreciated.
Pics;
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 01-06-2013, 01:05 AM
70TWO NOVA's Avatar
I guess Ill have to give them a call
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 01-06-2013, 03:20 AM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Looks like the one way valve came out. I recall there should also be a spring, but it's not used on every pump model. When pump is shoted down, the pressurated fuel presses the plunger against the pump frame closing way the pressure going true the pump back to tank.
You can run with out it but it maid be little harder(longer) to start up cos you dont have already pressurased fuel in fuelrails. Or you can run pre-pressurising relay/ or if running aftermarket injection, you can chance setting from ecu to run your fuel pump.
Most european/japanish cars have that kind of relay, when you turn ignition on, you can heard your fuelpump running acouple seconds.
Juhani
Custom Creations Oy (inc.)
CeeCeeOy IG page
Old 01-06-2013, 09:24 AM
1969x11's Avatar
1969x11 1969x11 is offline
Aeromotive 340's arent known for longevity in street use,I wouldnt take a chance on it. Send it back and get a Walbro.
Old 01-06-2013, 03:00 PM
70TWO NOVA's Avatar
which walbro do you recommend?
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 01-06-2013, 03:03 PM
THAT would depend on what you're running. A simple LS3 or a turbo'd 1000hp big block...
If the pump you're showing is adequate --- then probably the WALBRO 255 which is rated to 500hp... for EFI which I'm assuming you're running, NOT a carb.
Old 01-06-2013, 03:39 PM
1969x11's Avatar
Walbro 255. Do a search on Ls1 tech. I have no experience with the 340 but I have used the walbro in about 6 different builds and never replaced one. Plus they are 100 bucks.
Old 01-06-2013, 02:59 PM
70TWO NOVA's Avatar
do you know what order these parts go back in by chance?
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
