Old 01-10-2013, 03:32 AM
Stielow's Avatar
Stielow Stielow is offline
Bryan -
Engineers don't "glue" things ---- they BOND stuff together.
I used 3M Panel Bonding adhesive. Great stuff easy to use and a long working time. I needed to fill some gaps so it is also fairly thick.
I’m just working on little stuff while the car is at Sled Alley. It all takes time and if I can get some of the small sub-system parts done the assembly will go much faster.
I had a very good friend tell me, if you get one thing done everyday on your project you will finish your car . If it is just ordering a small part it is forward progress. You eat an elephant one bite at a time…..
Mark
Old 01-10-2013, 04:13 AM
garickman garickman is offline
Mark,
Any more work on your oil tanks and dry sump system. I would love to see how you package everything and see how you are going to make the oil fill and dip stick. Amazing work as usual! It is an art form to see how you engineer a car instead of "just building it". Thanks for sharing some of your knowledge.
Greg
Old 01-10-2013, 05:26 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Slick vs Stielow
The difference between "slick" and "Stielow"...
I had my stock mirrors dipped in hydro CF for a similar look... but not nearly as sexy as the real deal!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 01-13-2013, 09:48 AM
formula88's Avatar
formula88 formula88 is offline
Some project updates:
Mark modifies the passenger side of the subframe cross member to provide clearance for the AC compressor.
This requires rebuilding the engine mount pad and provides an good opportunity to improve vehicle refinement.
4th gen F-car OE engine mounts are being incorporated to reduce the noise and vibration over the aftermarket poly offerings.
Gordon
Old 01-13-2013, 10:35 AM
KPC67's Avatar
KPC67 KPC67 is offline
I know it was mentioned somewhere in red devils thread, but what acc drive do you use Mark?
I like the ac compressor tucked underneath as well.
Nice work on the fire wall and oil tank guys.
Kevin Carter
Old 01-13-2013, 10:41 AM
randy randy is offline
with the rear end lowered to a nice tucked stance were you ever concerned about hittting the bump stops? Im very very close on my 67 quadralink
Old 01-13-2013, 01:54 PM
I like the idea of utilizing a factory mount for less harmonic transfer into the chassis. That's one of the things I had thought of after building mine.
Old 01-13-2013, 07:04 PM
Steve68 Steve68 is offline
I have always planned on using modified rubber mounts to reduce vibration and engine noise into the interior of the car,
good idea!!
Old 01-17-2013, 08:32 PM
NvrDun71 NvrDun71 is offline
Hey Mark was curious which AC bracket you use to mount the V/A compressor and still work with the GM ls9 front drive?
71' Nova - LY6, T56
