Old 01-23-2013, 05:04 PM
AMSOILGUY's Avatar
AMSOILGUY AMSOILGUY is offline
Default Dual Remote Oil Filtration System
Check out what showed up at my place today.
After opening the box I was very happy with the hardware in the kit. It comes with a By-Pass filter that's changed every other full-flow filter up to 60,000 miles. Also a full-flow filter that's good for 1 year or 25,000 miles. Also you get a filter mount. The filter adapter is a quality piece. This is what replaces the factory full-flow filter.
Then its as easy and finding a good location and making a couple hoses.
The hoses where easy to make with a vice.
Now I am putting mine on a display. For installation on vehicle/equipment you want your filter mount in a good location for easy filter changes. It comes with 12' of hose. The instructions are very good.
A cool addition for any application! To get more info you can always go here: http://www.amsoil.com/shop/by-produc...ms/?zo=1856266 Preferred customers save 25%http://www.amsoil.com/opportunity.as...type=preferred
[email protected]
www.jacobehlers.com
Old 01-23-2013, 05:52 PM
Sieg's Avatar
Sieg Sieg is offline
Jacob - Any potential flow issues in high performance applications?
What's the core market for this system?
Old 01-23-2013, 07:18 PM
AMSOILGUY's Avatar
These are used widely on diesel applications which are performance driven. Although I have seen pictures of By-Pass systems on all kinds of applications from stationary to automotive. Proper length hose is important. It is recommened to allow room for movement when pressure is applied. Plus they look cool!
[email protected]
www.jacobehlers.com
Old 01-24-2013, 07:03 AM
AMSOILGUY's Avatar
This kit was for a 6.6 Duramax. Benefits of these systems are increased oil capacity gaining 50% more oil on some applications. More oil means the life of the oil and additives will have a longer service life. Easy filter changes which sometimes can be a pain. Superior filtration by filtering at 1 micron keeping the oil free of virtually all wear causing particles. If you have any questions let me know!
[email protected]
www.jacobehlers.com
