Old 02-04-2013, 10:30 PM
usa-69z usa-69z is offline
That would depend on your build. If you are building a rear end anyways, choose your wheel first with your dish preference and start fitting. It's best to measure your car because from experience no two cars are alike.
, so how do i work out my dish or backspace without a diff to measure from? Im after maximum dish i can run..with a 12 inch rim.
I had a measure of my diff today ,, its a tru trac moser ,, it has big drums,, did they use ford rear brakes on some of these? Im sure i saw a ford logo stamped into the backing plate somewhere when i purchased it? will that be a factor with getting rear discs or are the axle flanges the same stud pattern?
sorry i got a lot of questions here ,, i also thought narrowing each side 2.5 would bring the saddles very close to the axle flange..
Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 02-06-2013, 10:31 AM
Gav
If you want to simplify things, have moser weld on Chevy housing ends on. Pn 7900 or 7900FM (flush mount). This will allow you to use your parking brake backing plate as a bearing retainer depending on the disc brakes you run. The 7900 uses a large press on ford style bearing so that eliminates the c clip. If you already have your rear end and need to narrow it, you can cut off the ends and replace with the 7900's. You can get your axles cut and resplined and change the bolt pattern to Chevy 5x 4 3/4.
Old 02-07-2013, 08:14 PM
v8s only's Avatar
v8s only v8s only is offline
my 69 camaro has 55 inch rear end wheel mounting surface to wheel mounting surface that's 5 inches shorter then stock wheels are 18x12 5.5 back spacing fits perfect in my car
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 02-08-2013, 03:41 AM
Thanx Tony ,, that seems to be the average combo for the mini tub im finding..
Gav
Old 02-08-2013, 03:40 AM
Vince , i do already have a chev pattern tru trac Moser rear,, but im thinkin i have ford big brakes as it got the torino bearings ? I just thought the flange pattern maybe different to a stock chev flange pattern, ill have to measure it..THe spring pad mount on the diff would be very close if i narrowed it to 55 inches.. do they end up being that close to the disc and bracketry?
Gav
Old 02-09-2013, 12:27 AM
Gav
yes, you would have to move the leafs in too.
Old 02-28-2013, 07:52 PM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Tony,
So a 1969 Camaro stock hub to hub is 60"? I was told the Z28 is 58"? Are they different for different X codes? Just asking.
Gav,
As Vince suggested, brakes also may play a role. I'll probably go with the stock width rear and stock dish making replacement a cinch. I'm going with Moser full floater (steel hubs) and PBRs on Willwood GT rotors. GMR makes the mounts for the PBRs and a sweet little parking prake optiion. At 58" as a standard width it will be easier to get a replacement if needed. I'm sure Moser can and will make any width but they have specific widths already in stock. And from what I see they have good prices. Are you dead set on keeping the 12 bolt? Just a thought.
David
David
Old 03-01-2013, 04:39 AM
David , yes the diff will be at 55 " ,,I have already got a moser rear custom built a few years back and will now have to have it narrowed to suit.. also the g bar rear needs the mounts welded to the diff. No big deal , just im impatient and i wanna drive the thing sooner than later..
Originally Posted by Stovebolter View Post
Tony,
Gav,
David
David
Old 03-02-2013, 05:42 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Generally speaking you want to select the wheels with the offset you like first. Then mock them up under the car to determin the WMS to WMS width of the rear end. Here is a good post on exactly what the WMS measurement is and how to measure it. Just for the record, my rear wheels are 18x12 with a 5.9" back space. I mocked them up under the car where I wanted them and determined that I needed a 57" WMS to WMS rear end.
http://www.pro-touring.com/showthrea...Mount-Surface)
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
