Old 02-08-2013, 04:12 PM
coolwelder62's Avatar
Originally Posted by sixnina View Post
Scott,
Awesome work looking at subframes for my project and was wondering about options and pricing as well if you don't mind Pm'ing me.Thanks Shane
PM,sent Shane. Thank's for asking.
Old 02-09-2013, 09:15 AM
exwestracer's Avatar
exwestracer exwestracer is offline
Nice piece, Scott!
Sorry if this is a stupid question, but are you using a curved sway bar arm? I ask because the bar tube seems pretty close to the height of the LCA mounts.
Any pics of the bar "mocked" up in there with the end links, etc?
Ray Kaufman-Wyotech chassis fab instructor
Custom suspension design and consultation.
(Now 2) Big Block asphalt supermodified ('cause too much is never enough...)
Old 02-09-2013, 11:38 AM
The center of the sway bar is 1.25 higher than the LCA mount center.And I bent the splined sway bar arm so there is no binding with 1/2 rod end links.
Old 02-09-2013, 12:11 PM
Ah. Are you using a M/F heim set up for the end link?
Old 02-09-2013, 12:50 PM
p51mus p51mus is offline
Default frame
Did I see that you are going to build an all aluminum frame also? Thanks, Garry.
gb69z
Old 02-09-2013, 05:30 PM
Yes, 1/2 male & 1/2 female heim w/cone spacer's.I will find you a close up photo.
Yes,Making drawing's Now for the CNC cutting table.Materials in house.
Going to build one proto type then test.Figure's show that the bare will only weight #58-62 lbs.6061 material & completely tig welded.(No paint needed)
Old 02-17-2013, 06:50 PM
Kevin,Started the final welding on his sub frame today.Should have all finished in a few Day's
Old 02-17-2013, 06:58 PM
Here is a photo of the heim ends used to conect to the LCA.
Old 02-17-2013, 07:04 PM
itsals1 itsals1 is offline
Looks like he takes after "The Old Man" ! Nice job on your frames!
Travis
Old 02-17-2013, 07:17 PM
Travis
Kevin is prob, a little steadier w/mig gun these day's.He's 22 year's younger than I am.
