While waiting for my front suspension it dawned on me that there is only one adjuster nut for the coil over. Has anyone had any issues with this thing backing off? I'm used to seeing the two nuts that take a standard spanner wrench.
The shocks either have another ring that locks against the coilover ring, or it has a set screw. I can't remember which. Maybe it is both. Either way I think it is pretty safe to assume that if it is coming from DSE you won't have an issue.
As Matt said its a locking ring under the coil adjuster ring, nothing more than a jam nut. Just instaled four of them, you wont have problems great quality.
On the DSE/JRI Coilovers I have there is a set screw in the adjuster ring. My shocks have the non adjustible valving. Just finished Speed Kit 2 and Quadralink install.
