Old 03-03-2013, 07:14 AM
Originally Posted by Amituk View Post
For any of you beginners,
Jason's (from theGmr) ebook is an awesome guide for $4
http://www.amazon.com/gp/aw/d/B00BFX...dir_mdp_mobile
Certainly helped me!
I was hoping that a few of the better guys would chime in here.... I'm certainly no expert!
Old 03-03-2013, 07:58 AM
Some very good info right here.....
Old 03-03-2013, 07:06 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Hi Guy's looking for some help. I haven't picked up a tig in years and haven't welded much stainless. Below are a couple of pictures. I have tried a few settings an I ended up at 30 amp and no filler rod, at that setting I don't have any real undercut, but I'm concerned about the lack of penetration. Any help would be appreciated.
Greg
Old 03-03-2013, 07:11 PM
Greg
Attachment 38613
Attachment 38614
Give us some more information --- like the gauge of the metal...
Old 03-03-2013, 07:22 PM
Greg, It's about 13 gauge. Also I'm using a 1.6 mm tungsten and a gas lense.
Greg
Old 03-03-2013, 07:35 PM
Greg
13 gauge tube is about .095" which is 1/16th of an inch we'll call it....
Miller weld calc calls for 50 to 80 amps for TIG on Stainless butt weld.... using a 1.6mm tungsten and same size filler... Gas flow should be about 11 CFH
So you're close.... Personally I like to choose a bit on the high side of the range -- because I can back off the amperage with the foot pedal -- or hand control and just use whatever it takes to get the job done.
Old 03-03-2013, 08:23 PM
When I was at 45 amp, I was getting undercut, which isn't ideal either.
Greg
Old 03-04-2013, 04:39 AM
Sieg's Avatar
Sieg Sieg is offline
For optimum results on tubing isn't it advised to back-purge the tube with argon to reduce sugaring?
Old 03-05-2013, 07:31 AM
Yes -- on HEADERS etc.... but of course not if you're building a roll cage. So "it depends"....
On headers etc you want smooth flow which means keeping the inside of the tubes smooth. Sugaring also leads to cracking and corrosion. Purging also gives better penetration.
Old 03-05-2013, 07:36 AM
Notice the WIRELESS foot control??? That is why I bought one at SEMA a couple years ago...
We're working around various "stuff" --- we're not usually sitting at a bench welding all day. It's just one LESS cable to mess with. I love mine!
