Old 03-02-2013, 02:23 PM
Default Tig 102
Who's the first one to tell me TWO things you see that's wrong with this TIG welding.... I'm not spilling the beans on what member this was (not me!) but in discussing it with her.... (HA HA!) I realized that maybe more than one or two of you new TIG "welders" aren't familiar with a couple of the "don't do's"
Old 03-02-2013, 02:33 PM
Sieg's Avatar
Sieg Sieg is offline
Subscribed!
Old 03-02-2013, 04:14 PM
Rhino Rhino is offline
Too much amperage and dirty tungsten?
Old 03-02-2013, 04:44 PM
<< BUZZER >> Wrong!
Sorry.... Keep trying! You get more than one guess....
Old 03-02-2013, 04:57 PM
Ketzer's Avatar
Ketzer Ketzer is offline
First off, I thought you said magnets were baaad... Uhmmkay (SouthPark reference). Secondly, it looks like the same thing I'm doing wrong so I'm also subscribed...
Jeff-
Old 03-02-2013, 05:04 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Metal not clean
Old 03-02-2013, 05:30 PM
Well Jeff has HALF of it right! DING DING DING DING
NO TIG around Magnets!!! Makes the arc wander all over the place.....
I don't think anyone will guess the other problem ----- the welder ran out of Argon....Newbs -- remember to change out your bottles when you get down in that "less than" 500 psi and that won't happen.You know these are like propane BBQ's -- you'll run out in the middle of cooking on Sunday afternoon...
And since Tonnes mentioned CLEANING here's some pics of unclean and cleaned! I copied these off Miller website.
UNCLEAN Steel
Same metal cleaned properly!
GEE!!! SEE ANY DIFFERENCE??
UNCLEAN Chrome Moly
CLEAN Chrome Moly!!
Old 03-02-2013, 05:34 PM
Here's something else that I'm personally guilty of... the "if a little is good more must be better syndrome!"
Welders commonly—and incorrectly—assume that a higher gas flow/pressure provides greater protection. In fact, excessive gas flow creates turbulence and swirling currents that pull in unwanted airborne contaminants (and it can cause arc wandering). Generally, err on the lower side of recommended shielding gas rates to ensure proper shielding coverage without turbulence.
Old 03-02-2013, 05:36 PM
I'm laughing to myself at this comment... just to poke a sharp stick in an eye ---- but YEAH.... probably that too!
Old 03-02-2013, 08:03 PM
That's why I work IT and just "glue" stuff together at home
It is quite amazing the difference a little contamination makes. Growing up with a mig in hand it was a bit of a shock to pick up a tig the first time. They seem just a *bit* less tolerant.
