Old 03-06-2013, 10:53 AM
Rybar's Avatar
Rybar Rybar is offline
Check your O2's or possibly replace them. One of mine went bad on me.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 03-06-2013, 01:29 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
ok, i was thinking it could be the trans since the fluid was so low. I appreciate the ideas. Ill keep all this in mind while troubleshooting
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 03-08-2013, 07:38 AM
70TWO NOVA's Avatar
well I checked a few things the other night, I couldnt find any obvious issues, cylinder 7 is definintely missing though. Also the transmission was really low. I guess I didnt put enough fluid in when I initially filled it. It took a good 2.5 quarts. I guess that would explain it not wanting to go anywhere when I tried to accelerate. But I still dont get why the engime didnt want to rev...
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 03-10-2013, 08:03 PM
70TWO NOVA's Avatar
A little update, I think I narrowed it down to the trans being in "limp mode". All the research I did points to this. The engine seems to being running fine but the trans is stuck in third gear (will go into 2nd if done manually) I do have reverse though. So I did a little testing and made sure there is 12v going to the trans and that the VSS is operating (I even swapped it out with a new VSS, no change) From here Im not sure what to do. How do I clear the PCM from limp mode? What else would cause this? Anything else I should check? Any additional help is greatly appreciated.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 03-10-2013, 08:12 PM
tooblue's Avatar
tooblue tooblue is offline
A good start would be to see what the ECM is telling you by reading the codes. With out the codes you are shooting in the dark.. Roger
1995 Caprice,, LQ4 = 6.0 , L92, 4l65e, Phoenix AZ..
http://www.cardomain.com/ride/456803...caprice/page-1
Old 03-10-2013, 08:15 PM
70TWO NOVA's Avatar
I bought a bluetooth adapter so I can read the codes on my phone, should be here wed. Wish I bought this earlier
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 03-11-2013, 07:37 AM
71RS/SS396's Avatar
You can rent the code reader from O'Reillys and other parts stores, most will rent for free, just leave a deposit and you get the deposit back when you return the tool.
