View Poll Results: 2 Dynos one winner Big Block Ford vs SB2
Sideoiler Makes the most peak hp 2 4.44%
SB2 Makes the most peak hp 18 40.00%
Sideoiler has the best average hp and tq (3500 to 7000) 12 26.67%
SB2 has the best average hp and tq (3500 to 7000) 13 28.89%
Voters: 45. You may not vote on this poll
Old 04-26-2013, 09:25 PM
Track Junky's Avatar
Gaetano Cosentino
Old 04-26-2013, 09:28 PM
DG has a new goal. Spend $51k building a Chevy
Shiat... I better get a full suspension, wheels, an engine, and much more for that number.....
Or I could get an IRS and an FE.... pretty easy choice there.
Did you send that from your iphone?
Old 04-26-2013, 09:34 PM
Clever
Gaetano Cosentino
Old 04-26-2013, 09:48 PM
Ron in SoCal's Avatar
Naw, all you need is a billet pan
Ron in SoCal
69 Camaro in progress
Old 04-26-2013, 10:28 PM
FETorino's Avatar
FETorino FETorino is offline
No matter what get a contract before you hand over the $$
Rob in SoCal
Old 04-26-2013, 10:35 PM
I am on my 3rd and final oil pan for this dang engine.
Too late. I better go over there tmrw and see if the shop is still there.
Old 04-26-2013, 11:15 PM
intocarss's Avatar
Old 04-30-2013, 10:29 PM
FETorino's Avatar
I should have just used a set of Blairs pro port Edelbrocks.
http://fepower.net/simplemachinesfor...;last_msg=9237
Originally Posted by jayb link=topic=1074.msg9235#msg9235 date=1367381249
Information is a little sketchy on this one at the moment; Blair has promised to come on in a few days and provide some more details. But these dyno numbers are unreal for what this engine is:
Photo quality of the dyno sheet is poor because it was taken with Blair's cell phone camera. I have never seen an 800 lb-ft FE except for my big SOHC, and that engine was 585 cubic inches. This engine is only 506 cubic inches. That is a very, very impressive torque number. And the horsepower peak of 911 HP from 6400 to 6600 RPM is also really impressive.
I spoke with Blair on the phone tonight for a while about this engine. Apparently it is basically one of his Super Stock FEs, but with more cubic inches, less compression, and a smaller cam. His normal 427-based super stock engines turn to 9000 RPM to make this kind of horsepower. Compression ratio on this engine is 13:1, and the cam is a 270@ .050" duration cam with about .700" lift. The idea behind the engine is that the reciprocating assembly and cam can be changed and the engine will turn into a legal super stocker. The heads are Blair's pro-port Edelbrock heads, and the intake is a tunnel ram style intake with two 715cfm Holleys. Blair pointed out that the heads and intake were ported and tuned together on his flow bench, to really optimize the combination.
That's about all I know at the moment, but I'm sure we'll hear more in the coming days...
Rob in SoCal
