Old 05-12-2013, 05:29 PM
Very nice power numbers. I have to ask though, what part does having a supercharger and now even more power play in a drift competition? It appears you have plenty of power to keep the wheels spinning and as I understand it, it's more about follow the leader than get to the finish line first. So did you need more power or does it give you better advantage somehow?
Good luck this season!
Old 06-06-2013, 09:22 AM
syborg tt's Avatar
Car looks great I would love to see it in Action.
marty-mj
Old 03-19-2014, 01:06 PM
MikkoV MikkoV is offline
Evolution of Camaro continues
I did re-design front suspension. Removed front springs that were between frame and lower control arm. Made new upper mounts for coil-overs. S13 coilies, modified lower end. Also changed upper controld arms to SPC adjustable ones, here comes Caster.
6-rib charger belts didnīt hold up that long last summer, changed over 10 of them during summer. So i did bought Summit SFI 8-rib balancer and changed 8-rib charger pulley and belt. Hope it helps... Gates belt align lazer was great help when aligning pulleys, good buy from Rockauto.
Re-made fuel lines from enginebay. With ebay cheapo AN fittings and Nylon-braided fuel line that should accept RE85, also Holley fuel rails had been allready changed after last posts.
Also changed original throtle body that had been modified from DBW to cable driven. It didnīt work properly and eated couple of TPS sensors during 4 summers. Ebay china-billet one seemed quite good for itīs price.
Also did made support bar to back of bonnet. It was quite restless in high speeds without additional rear center pins. Also should keep smells at engine out from cabin. Heater inlet is front of screen as usual.
[img]http://forum.vastaheitto.com/index.php?action=dlattach;topic=4116.0;attach=6257 ;image[/im
....to be continued
Chevrolet Camaro LS3+T56 "-70" Drift & Track
Dodge Charger 500 -70 ???+??? Pro-Touring style project
Opel Manta A 3700 -71 Euro muscle.
Old 03-19-2014, 01:18 PM
syborg tt's Avatar
Looks very nice I can't wait to see you tearing it up on the track.
marty-mj
Old 03-23-2014, 03:10 PM
Finally...
Hereīs video from last season.
Old 03-24-2014, 05:05 PM
pjs65 pjs65 is offline
Nice video , you certainly know how to chuck that 2nd gen about . pete
Old 03-24-2014, 05:24 PM
Nice work...isn't it great having all that power to get your control easier?
