Old 05-15-2013, 03:13 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What hp?
I'm thinking you'll want the magnum.
Old 05-15-2013, 06:41 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Originally Posted by MarkM66 View Post
What hp?
Haven't got it on the dyno yet. Depending on the boost level, I'm going to say all of 600hp. Its the V2 Vortec, its pretty damn efficient so I am thinking it will be a 150hp bolt on when its all said and done, at least. Im not sure what the tq. curve will do with a charger?
I have no problem spending the money up front if the magnum is that much better? I believe the Magnums are rated to 700hp/700tq. What are the LS/LT T56's rated to?
Thanks, Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 05-15-2013, 08:48 PM
stock, many people will argue which is stronger, LS or LT T56. If you're going to rebuild or upgrade, it doesn't matter. They are very similar transmissions on the inside. Both will handle your power levels with the blower unless you're planning to drag race the car and launch hard with sticky tires.
The LT T56 will bolt to an SBC easier than the LS version since the bellhousing is a more integral design on LS version.
The only other thing to consider and research are the different gear ratios/models of T56s. 93 had two different T56s available with one having a lower first gear. Not easy to find any more I bet but might be worth the hunt. LS versions have the MM6 and M12. The 6 was found in fbodies with the M12 in GTOs and maybe CTSv. M12 had lower first gear and lower 2nd overdrive. You'll have to take into consideration the funky shifters on the GTO and CTSv versions though. I'm willing to bet that any normal LT T56 will work just fine for you and be the easiest to install with the conversion bellhousing. That's the route I would take.
Old 05-16-2013, 07:12 AM
NorCal72's Avatar
This is exactly the kind of information I've been looking for. It honestly scares the **** out of me to count on a vendor to know exactly what I need. Any recommendations on a "one stop shop" for everything Im going to need for the swap. Im considering Hurst and Kiesler at the moment. With me being overseas so much I pretty much have one shot to get it right or I will be delaying the build 3-4 months. I need to have this thing on the road by the end of the year. As I sit right now Im waiting to here back from a member here with a LT-T56, if that pans out I'll be going that route. If not I think I'll be getting a Magnum. Thanks again for the reply's this site has been a great help.
Old 05-16-2013, 07:16 AM
Hurst has had great feedback from customers. Some others have not.
Old 05-16-2013, 08:04 AM
NorCal72's Avatar
Got it! Thanks a lot for telling me about your front sub LOL. I was always planning on dropping my current front clip under the 57' truck. I think you just sped up the timeline considerably.
Old 05-16-2013, 05:39 PM
Not sure on a one stop source for everything. Your situation kind of changes things really. The only thing I can think would be to research everything needed and get the miscellaneous parts ordered from you favorite vendor. Putting an LT T56 behind a two piece gen 1 SBC is nothing new. Nastyz28.com I bet has a guide for doing the conversion.
