Old 06-28-2013, 05:11 AM
protour73 protour73 is offline
Since I've heard no mention of this as an issue I was wondering if I was the only one fighting the stock pedal configuration.
Are you kidding me? Pretty much the identical issue in the 2nd Gen as well. I searched a truckload of aftermarket pedal sets that don't solve the issue.
I did end up with a set of Modo Innovations pedals as they were the best looking. The biggest issue is the massive difference in height between the brake and gas pedals. I've thought of using spacers to raise the height of the gas pedal assembly......but I never pulled the trigger, this thread has inspired me to get back on that idea!!!
Great job Sieg, wonderful fabrication!!
Old 06-28-2013, 06:18 AM
carbuff's Avatar
carbuff carbuff is offline
We did exactly that on TOW. By raising the gas pedal and dropping the brake pedal a little, we found a much better match on the gas/brake pedal heights. I was pretty unhappy with them at first also!
Nice job Sieg.
Old 06-28-2013, 08:10 AM
intocarss's Avatar
I did the same but your bracket looks nicer Good job Mr Seig
Old 06-28-2013, 08:16 AM
Sieg's Avatar
Sieg Sieg is offline
Nice job Sieg.
Thanks Gentlemen
You too Dawgy!
Old 06-28-2013, 09:14 AM
ccracin's Avatar
ccracin ccracin is offline
Nice Job man! That's a great solution to a problem I wish we had. Drive-ability! Right now our drives like it is on rails! Wait a minute, it is on rails, 10" beams to be exact.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 06-29-2013, 07:00 AM
intocarss's Avatar
Thanks Gentlemen
You too Dawgy!
I see what you did there
Old 06-29-2013, 07:23 AM
Sieg's Avatar
