Old 07-05-2013, 06:40 AM
The C5 caliper bodies are much stronger than Fbody calipers. C5s are also 13inch not 12.1 like Fbody. Even just simple Solo2 Autox would wear out and distort the Fbody calipers. Like I said, the Fbody stuff will be better than 1st gen but the C5 components are even better. The cost difference to mount C5 front calipers versus Fbody is negligible. For the rear, sure Fbody is cheaper with the integrated parking brake. You could also go with C4 Corvette or LT1 Fbody for the same reason. Those options will work just fine for the rear.
In short, do it twice and spend more money by going with Fbody calipers now only to change them out at a later date. Or do it once and save money by going C5/6 on the front now. There are a lot of 17inch rims that will clear C5 components. You won't have to spend a lot of money on rims to make things fit. My rims cost me $600. I've got another $200 in adapters and ARP studs. My rims are 18inch too.
Old 07-05-2013, 06:48 AM
hifi875's Avatar
hifi875 hifi875 is offline
Fronts are 12.8 rear are the exact same as c5
Old 07-05-2013, 08:59 AM
69greyghost 69greyghost is offline
What rims do you have? Can you post a pic? Also I have the brembo 2010 camaro calipers. I may as well try and use those.
Old 07-05-2013, 08:37 PM
BMW M-Parallels is what they are called. Follow the link in my signature for pictures. The last page should have them.
You're correct about the rears, Hifi. I was confusing LT1 4th gens which have the integrated parking brake with the caliper. That's a cheaper and easier way to do a rear conversion than using C5 rear brakes. LS1 fbody fronts are not 12.8 inches though.
Old 07-05-2013, 08:54 PM
Those wheels are badass!!! I am gonna get a set asap!!!!
Old 07-06-2013, 01:52 PM
Thanks. Good luck finding them. It was late 90s early 2000s 5 and 7 series BMWs that had them. I believe only the 7 series had the staggered 8 front 9.5 rears like I have. I used Craisglist when back in Georgia to find them.
Just keep in mind that there are a lot of inexpensive OEM rims out there that will look good and clear 13inch front brakes like C5/6 brakes. You may have to get adapters to make it all work but it's not difficult typically and should help you stay well within your budget.
Old 07-06-2013, 02:56 PM
Thanks trey, one more thing, do you know if the brembo 2010 camaro rotors and calipers will fit behind those wheels?
Old 07-07-2013, 07:36 AM
I have no idea. I don't know what backspacing or offset is needed for a first gen. The backside of the rim center is not that close to the caliper though on my car. Keep in mind that I have 3/4" adapters on my car to push the rim out more too. You may want to PM Jerry, intocarss, as he has a set on his 68 camaro. I'm sure he can tell you more about what it takes to get the rims onto a first gen.
Keep in mind that modern OEM rims are typically high offset rims. That means you'll have to add adapters to bring the hub of the rim back to a lower offset, towards the middle of the rim, or, another way to think about it, push the rim out towards the body of the car. You'll need to take that into account when selecting a rim not only to know what adapters you'll need but also to include the adapter thickness in when trying to determine if the rim will clear the calipers.
Old 07-07-2013, 06:45 AM
hifi875's Avatar
Yes. I was wrong about the fronts. My bad. I want some z51 rotors and calipers now.
