Closed Thread
Old 07-14-2013, 06:08 PM
Sieg's Avatar
Sieg Sieg is offline
Ron,
I meant Rob - as he requested my data in a PM...........
But Ron, thank you very much
I have a spare stock subframe sitting in the garage that I plan to do on a budget somewhat "Smokey" style and this information greatly helps the quest.
My current setup is somewhat goofy as I feel it handles much better than it should, but I've yet to get it to the track and exploit the short-comings. FWIW my only road course experience is on two wheels.
Again thank you for sharing this information, it is very much appreciated.
Old 07-14-2013, 06:53 PM
Ron Sutton's Avatar
Ron,
Oops! No worries.
You're welcome.
Hmmm. Where are you located? I have some ideas, but would need to show you in person on the clip.
Well that's cool.
Cool. I love bikes but only raced motocross as a kid, never road courses. I'm sure it's a thrill.
Take care.
Ron Sutton Race Technology
Old 07-14-2013, 07:04 PM
Sieg's Avatar
Originally Posted by Ron Sutton View Post
Take care.
I'm located in Springfield, OR.......near nothing.
Old 07-14-2013, 07:07 PM
Wissing72's Avatar
Wissing72 Wissing72 is offline
Hey I grew up in Eugene. I remember when Springfield really had nothing but a Pulp mill!
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 07-15-2013, 09:09 AM
intocarss's Avatar
And now all that is there is Pulp fiction
Old 07-15-2013, 10:31 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Ron, one more question on KPI/SAI: is the angle relative to ground plane? In other words, does the KPI change when static camber is changed? Or is it a hard angle directly from the manufacturing geometry of the spindle? So with a particular spindle, the KPI angle would always be the same for that spindle? Just wondering as I am trying to visualize all this. I like your analogy of the wheel turning 90 degrees, it's easier to see whats happening.
What an awesome discussion, thank you.
Oh, more Torino pics Rob!
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 07-15-2013, 10:36 AM
65_LS1_T56's Avatar
Me so sorry
Aaron
65 Chevelle
Project G-Velle
Project G-Vette
Old 07-15-2013, 11:12 AM
Bryce Bryce is offline
KPI is spindle dependent not camber dependent.
Old 07-15-2013, 11:28 AM
Ron Sutton's Avatar
I "believe" front end alignment machines show it relative to the ground, which would change with camber. But that's not how we do it, nor how we see it in racing.
Correct, it is a hard angle that does not change, regardless of camber. It is the angle difference from the wheel hub axis compared to the centerline of both ball joints.
Yes, the KPI stays the same on a spindle, unless you physically modify it.
Modifying the KPI of a spindle is not common for street cars. But it can & has been done with welding up the ball joint holes & re-milling them in a different location. Some racers "cheat" this way in classes where "stock spindles" are required by rules.
Also, there are racing spindles with a removable slug in the top, for the upper ball joint. Different slugs move the upper ball joint location in towards the wheel or out away from the wheel, effectively changing the KPI. They also have removable steering arms where the lower ball joint mounts. To keep the ball joint alignment true to each other, this lower arm is changed too.
I have run this type of adjustable KPI spindle, but don't prefer it. It's fine for testing stuff. But I know what I'm looking for when I order custom spindles & have designed the whole package to work together. There is no need to change it later.
Cool. I am very visual. So I need to see or at least visualize things working to understand them. I also found using BIG examples is an easier way to learn. Once you're clear on a concept ... you can always imagine the concept to a lesser degree.
You're welcome.
I don't think you're jacking the thread. Rob indicated he wants us to have these discussions. (I asked him)
If someone wants to ask specific questions about a different car, then we should start a new thread.
Old 07-14-2013, 07:21 PM
Ron Sutton's Avatar
I've been through Eugene before ... on my way to Portland. We're about 500 miles apart which makes it impractical, but I'm confident there are some low buck ... cut & weld mods ... that would make the stock clip work good.
You'd still need some aftermarket parts, but wouldn't need to spend a fortune.
Let me know if you move forward on it & we'll see if we can figure something out.
Closed Thread
