Old 07-24-2013, 01:15 PM
Sieg's Avatar
Sieg Sieg is offline
With your motor I'd probably go to 3:73 for maximum power leverage. Then see how they feel in the LS.
I was paying close attention to my rpm today on a typical trip to town and favorite backcountry loop and it's a fine line between 3:55's and 3:73's. I've been speculating on this too long, the 3:73's may win. 2250 rpm with my .63 6th and 26.5 tire is 75 mph, 2500 rpm is 85 mph.
The good thing about your trans is it doesn't have the low first gear........I've never understood why you'd want lower than the 2.66. Maybe really slow parades?
Old 07-24-2013, 10:59 PM
FETorino's Avatar
FETorino FETorino is offline
Actually I've never understood the .50 6th gear
A 4.10 rear gear will give you a 10.9 SLR which will make the car easy to drive on the street in slow speed stuff no matter what clutch or flywheel.
At 2200 rpm in 6th gear with a 26" tire you should be doing 83 mph so that seems like a nice hwy cruiser. At 2000 rpm you'd still be doing 75.5mph. I don't own an LS but I hear a mild one is happy at really low rpm so maybe less rear gear and running down the hwy below 2000 rpm makes the LS engine happy.
I'd choose between a 3.89 and a 4.10 especially if you aren't upgrading the motor soon. JMHO
Rob in SoCal
Old 07-25-2013, 07:36 AM
Payton King's Avatar
Default Go with the 4.11
Help get the car moving with the lower power level. I had 4.11 in mine and in 6th at 65 I was turning 1750 rpm with a 27 inch tall tire. Had 3.80's in and would turn 1500 at 65. Big pain with the 3.80 if I slowed up from 65 in 6th I had to down shift. I highly doublt you will make it into 5th on a road course with the power level you are currently at.
