Old 07-29-2013, 09:10 PM
Roberts68 Roberts68 is offline
That could work Chief! I like the suggestion of some black stripes or accents. I think that would look very nostalgic and still have a bad ass modern muscle feel to it.
Old 07-30-2013, 11:56 AM
Chassisworks Chassisworks is offline
Supporting Vendor
It could kind of be a new twist on the Smokey Yunick theme.
Old 08-04-2013, 12:20 AM
Sonar Chief's Avatar
Thumbs up
Been reworking the flanges on the mini tubs .... I didn't like the idea of clamping the tub over to the inside to make up the gap (close to 5/16") and then welding the tub under tension. So I flattened the flange, re-drew and made the flange where I needed it to be .... now I have a tub that is 2.75" through out the arc of the tub.
Take a look at the drivers side that has been reworked and re-flanged to make up the gap .... AND the flange is nice and crisp @ 90 w/o that 3/8 roll that came with the tub. Killed two birds with one body hammer and dolly
The black sharpie line was the old flange line ... moved it over a bit!
That's how they should be stamped!
The sharper bend will close that gap between the inner and outer wheel house and look way better w/o 1/2" seam sealer .... yes?
Getting there ..... little more hammer and dolly work and then the welder comes out
Thanks for looking .....
Old 08-04-2013, 12:25 AM
Thanks .... needs black fer sure. Thinking CHC 68 Project Redemption layout w/ that Desert Gold and black! I'll have to ask Chris' permission.
See above post for image!
Old 08-04-2013, 07:00 AM
Rick D's Avatar
Rick D Rick D is offline
Nice work Chief, yup that will look much better without the thick seam sealer!!
Rick
Old 08-17-2013, 11:39 AM
Thumbs up
Haven't work on her cuz my boys came out for a visit, one went home and the youngest stayed an extra week .... that's ok!
I'll get back on her this week .....
Old 08-18-2013, 04:48 PM
makoshark makoshark is offline
You really don't have to rub it into my face with those fancy new minitub flanges
Just kidding, I wanted to do that as well, but just didn't want to take the time to accomplish it. They look great!
Any chance your car is a factory a/c car? Mine isn't and I am installing the Vintage Air kit. I don't like the VA dash vents, so I want to go with the original style vent. They have an odd shaped hole and I'm having a difficult time marking out my dash to cut that hole.
Old 08-22-2013, 09:28 PM
Thumbs up
Jeremy .... sorry, mine is not an A/C car. Just got in off the road or I would have checked this sooner, hope someone has chimed in on your thread and helped out.
I wasn't rubbing in the flange
Old 08-23-2013, 05:28 AM
It's cool. I made a template off of a friend's 69 Firebird. If you plan to add air to your car and use the factory style vents, then I have a template along with my cutouts if you want them.
Old 09-01-2013, 07:52 PM
Thumbs up Update 9/1
Jeremy .... I will take you up on that offer when the time comes
Well ... I have had this list of things to get done rolling around in my head and I got some of them done over the past few weeks:
Mini tub ready for final fit .... quarter on order!
Set ride height on jig ... naw, new rubber wheels.
Clean these up ....
Much better!
Getting ready for Lizard Skin and some 3M bonding!
Almost ready for the skin!
Ouch, driver's side latch .... not good!!!!
So ... any suggestions on this driver's side latch? Are the repro's any good? I should be spraying epoxy primer tomorrow, Lizard skin and 3m bonding the passenger door skin if all goes well.
Spent most of today prepping and sweating the small stuff when I realized that I didn't have any room to MOVE the skin if I need to anyway ..... it's way too tight on the frame. Looks like I will have to use lots of GAP SPRAY
Thanks for lookin .....
