09-04-2013, 10:46 PM
What to buy 1st: rims/tires or drum to disc upgrade
Been pondering which to do first. I want 13" up front and 12s in the rear. Been looking at the Kore3 where I can use my existing drum spindles. Also saw the CPP big brake package but not sure if they still sell that. My wheels and tires will be 18x8 for the front and 18x10 or 11 in the back. Of course the car will be lowered to give it the right stance. I plan to autocross it as well. How do I get all the parts to work together without having a back spacing or non fitting problem?
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
09-04-2013, 11:02 PM
Buy the brakes first. The wheels should be ordered to clear the brakes. Would suck to buy the wrong wheels and they not clear the new brakes down the road.
09-04-2013, 11:13 PM
+1
Choose the level of braking performance you need and then fit the wheel to the brake selection.
09-05-2013, 10:14 PM
I second that. Besides that, going from drum to disc is still probably the best upgrade I ever did on my Chevelle. You get use to drum, but its a night and day difference with discs!
09-07-2013, 07:37 PM
Ok, so I'm looking at the Right Stuff big brake package. They say I can use my stock drum spindles. Is their drop spindle with the "improved geometry" worth it for auto crossing?
09-07-2013, 10:02 PM
no... the only drop spindle that I have used that improves the geometry(what geometry are they improving anyways?) is the ridetech spindle with their tru-Turn kit,,,,,,,,your better off using your old spindle and adding a tall upper ball joint then using the right stuffs "improved geometry" spindle if you cant swing the tru-turn
Rod Prouty
My website Auto-cross 101
Bangshift Stories
09-07-2013, 10:17 PM
If the car is rolling now and if you know that the rims you're wanting to buy or are going to buy will clear the brakes, I'd go rims first if this keeps the car on the road. Otherwise, brakes first. Brakes first especially if the car is still in project state and not mobile. You might change your mind on the rims between now and then.
09-07-2013, 10:30 PM
No the car is not rolling now. It's in the garage with 15" junk rim and tires. So once I get the brakes, I'd basically have to set it on jack stands until I got my wheels. That sucks but I guess it's motivation to go ahead and get them.
09-07-2013, 10:47 PM
I see. Yes, brakes first then. The brakes will look good on the car while it's sitting on the stands. Consider it brake porn
09-09-2013, 12:20 AM
Didn't see a tru turn spindle for the a-body. I will pass on the improved geometry for now. Can't wait to order my brakes tomorrow. I guess I need to order some more jack stands too
Thread Tools |
Display Modes |
Linear Mode
