Old 10-13-2013, 11:30 AM
garickman garickman is offline
Default Which gauges are most important?
Besides the Speedo and Tach, which other gauges do you feel are the most important to have in a dual purpose daily driver/road race autocross car. I have openings in the dash for six (6) 2 1/16 gauges. These were my thoughts in no particular order;
1. Oil Pressure
2. Oil Temp
3. Water Temp
4. Volts
5. Fuel Level
6. Fuel Pressure
Any thoughts on this?
Greg
Old 10-13-2013, 11:45 AM
That would depend on how many holes you need to fill. If I had to lose one it would be fuel pressure. EFI engines will let you know if fuel pressure isn't up to par.
Old 10-13-2013, 11:51 AM
I have six holes to fill. If I don't need the fuel pressure, what would be a better gauge to replace it with....trans temp, air/fuel??
Greg
Old 10-13-2013, 12:45 PM
Ron in SoCal's Avatar
Analog clock
I'd do an AFR. If it was blown, EGT.
Ron in SoCal
69 Camaro in progress
Old 10-13-2013, 01:14 PM
Musclerodz's Avatar
if its auto consider tranny temp
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-13-2013, 01:27 PM
carbuff's Avatar
carbuff carbuff is offline
Originally Posted by garickman View Post
1. Oil Pressure
2. Oil Temp
3. Water Temp
4. Volts
5. Fuel Level
6. Fuel Pressure
That's the same set which I chose. Fuel pressure is pretty uninteresting, although I can monitor it through my ECU so if I didn't have that one it would be ok. I'm not sure what else I would add, I think AFR moves too quickly to realistically be monitored by a gauge. There does come a point where you can actually have too many, although if you already have the holes, you may as well at least add something.
Old 10-13-2013, 04:31 PM
Yep, I'd take AFR over FP.
Old 10-13-2013, 06:33 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
If you are gonna drive it hard on tracks, in my opinion, a big red oil pressure light is the most important! The gauges are almost just "cool to have" in comparison
I do love much gauges though..
Old 10-13-2013, 11:31 PM
67goatman455 67goatman455 is offline
if its auto, your on the wrong site haha
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 10-14-2013, 12:31 AM
ironworks's Avatar
1. Oil Pressure
2. Oil Temp
3. Water Temp
4. Volts
5. Fuel Level
6. Fuel Pressure
What exactly is a daily driver road race auto cross car?
So you have 8 holes in the dash? Man that is a lot.
