  #15
Old 12-10-2013, 08:43 AM
Ed.Capen's Avatar
Ed.Capen Ed.Capen is offline
Good Guys
Well a little more work on the Nomaro project this past week. The quarter is all one piece now and ready to install. We had to add to the front and back of the 69 Camaro quarter to make it fit the Nova lenght. As you can see we also had to install a Camaro inner fender as the Nova one was lower than the Camaro on the outside edge.
Here is the Quarter on the car with it lined up to the door.
You can see how we were able to leave the rear section of the Nova and make the body line work with the Camaro.
Here you can see the little piece we added to the rear window area to make it line up with the door edge as the door on the Nova is just slightly shorter. This piece added to the window area will just cover the glass by about 1/2 inch. Much less work than sectioning the door...
Here is a look to see one side together with the front end and the door lined up. Starting to look like the car in the rendition...
Now we can work the other side and then off to body work and paint.
Ed
[SIGPIC][/SIGPIC]
