Old 12-16-2013, 12:44 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by 64mali View Post
I just looked at the website and like what I see. If I understand it correctly it looks like all I need is the billet hub and big brake kit or do I need to get the AFX spindles? Have any of you guys run these brakes? What's the feedback?
I'm running the C5 big brake kit up front w/ Wilwood 7/8" manual master and Hawk HP+ pads, and drums in the rear. With 245/40/18 Nitto NT-05's up front I have more brake than grip. Modulation is very good IMO.
Old 12-16-2013, 10:08 AM
130fe 130fe is offline
Sieg, what wheels are those VWW? what size backspace are you running, any spacers? Any info would be appreciated.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 12-16-2013, 11:06 AM
HELLCAMINO HELLCAMINO is offline
Can't beat a set of brakes from a 1998-2002 LS1 Camaro. Front and rear mounting brackets availible online. Grab some drum hubs and have em turned down to fit the rotor hat or buy a set of billets thru Kore3. Does the job for me on a budget. I got amy fronts on Craigslist for $200 and the rear set up off Ebay for $130. The drum hubs I got for free and you need disc spindles or if you have drum spindles they need milled down for rotor clearance. Most 17" rims will be fine, but 18's are the way to go for max clearance.
Old 12-16-2013, 07:55 PM
Sieg's Avatar
Vintage Wheel Works V-40's 18x8 w/ 4.5 bs and 18x9.5 w/ 5.5 bs.
No spacers, pan head allen bolt used in top of front wheel opening, tight clearance in the rear may require a little inner wheel well massaging with a hammer. Rear outer fender lips have not been rolled but it wouldn't hurt.
Old 12-28-2013, 08:19 PM
64mali's Avatar
64mali 64mali is offline
Has anyone tried the big brake kits from Matts Classic?
Old 12-29-2013, 11:53 AM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Hello, are you looking at the Right Stuff big brake kit? I have it on display in the showroom.
If you need more details let me know, bang for the $$$ its GREAT!
Matt
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 12-16-2013, 05:06 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
X2 on Sieg's setup. I'm running the C6 in 340/330mm front/rear rotors with HP+ and a 7/8" Wilwood manual master as well. Phenomenal braking with excellent modulation. An adjustable prop valve is a must though.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 12-16-2013, 06:28 PM
aany001's Avatar
aany001 aany001 is offline
Call Tobin at Kore 3 he will set you straight!!!!!
