Old 07-10-2006, 04:20 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Default more pics
96z28ss's Avatar
Old 07-11-2006, 12:10 PM
Rybar's Avatar
Rybar Rybar is offline
Your car is coming along real nice. What are the specs of the motor? 346 Ls1 with AFR's?
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 07-11-2006, 01:42 PM
Datsbad's Avatar
Datsbad Datsbad is offline
Looks like a LS2 to me
The absense of knock sensors in the middle give it away and the front timing cover .
Looks good man . Are those heads out of the box or have they been built . I personally would never bolt on a set of heads right out of the box from any of those companys. Just curious.
Fill us in on the motor????? I see a little something famillar in the background Overseas maybe???
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 07-11-2006, 02:14 PM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
What inclined you to go with a Strange rear diff. over a Moser? I am unsure about which one I should go with for my A-body, and I am trying to get some different opinions.
Old 07-11-2006, 02:22 PM
96z28ss's Avatar
LS2 block,
Eagle 4.0" crankshaft,
Callies 6.125" H beam rods,
Wiseco custom forged pistons(4.03" 1.110CH 26cc rev. dome lat. gas ports, NPR stainless chrome rings
Federal Mogal 152M mains,
Clevite cb663 H rods brgs, Dura Bond cam brgs,
ARP main studs
Cam Motion custom LS1 camshaft
Roll master double roller timing set w/ torington bearing & nitrided gears.
Comp cams lifters
ARP LS2 head stud kit
Cometic head gaskets
Jesel Rockers
Comp cams push Rods #7955-16
I just didn't have time to build this engine, I built the engine in my last car 396 LT4 and I know how long it takes to verify all the clearances and assemble the engine.
So I enlisted the help of LME (late model engines) in Texas
The motor is 9:1 compression and it is built so I can run twin turbos.
The heads are ported and polished and I sent them down to Texas to assemble the long block. I'll put the rest of the engine together, also I'll build the headers and get the turbos on there.
It will have a FAST intake, throttle body, and fuel rails. it will run on a Big Stuff 3 computer.
Old 07-11-2006, 02:24 PM
96z28ss's Avatar
I had a strange 12 bolt in my last car and was really happy with it so I went with it again.
Old 07-11-2006, 02:29 PM
You gotta go with what has worked in the past i guess
Old 07-11-2006, 07:10 PM
Datsbad's Avatar
what is the intake above the motor in the background.
Sounds sweet, twins would be real cool !
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 07-11-2006, 08:14 PM
96z28ss's Avatar
I'm not sure what the intake on the bench is. Its not for my car. I can't afford the intake you used. I had to go with a FAST intake.
I'll ask and find out for you and maybe get a better picture.
