Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 01-29-2014, 03:51 PM
intocarss's Avatar
I would mount it to tword the front of the DS. I'd rather have the rear of the DS hit the ground then the front.. NHRA rules say 6" back from the transmision
Old 01-29-2014, 04:08 PM
67Rally's Avatar
67Rally 67Rally is offline
Thanks guys, I don't think I was very clear. I know the safety loop needs to be within 6" of the centerline on the front U-joint.
My question was whether there was a rule about where the H-pipe or X-pipe falls in relation to the loop (i.e. does it have to be in front of the loop or behind it, or does it not matter?)
Old 01-29-2014, 04:12 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Most rule books specify the DS loop be located no more than 6" behind the front U-joint. If you happen to have sub frame connectors installed that is a good place to mount a DS loop. There is no rule pertaining to the exhaust that I have ever seen.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 01-29-2014, 04:32 PM
67Rally's Avatar
I think Mythbusters did an episode on the pole vault theory and couldn't make it happen.
I posted a similar question on TC and got the same answer that it didn't matter where the pipe went.
Here's the thread that I was referencing:http://www.camaros.net/forums/showthread.php?t=193442
They mention that the X-pipe has to go behind the safety loop. But in reading it again, maybe they meant it was the only place it would fit, rather than that it was a requirement.
Old 01-29-2014, 04:36 PM
67Rally's Avatar
Here are the quotes:
With a driveshaft loop you are pretty limited, the X has to go behind the safety loop.
And
The NHRA required driveshaft safety loop has to be within a few inches of the front U-joint. I wish I had a photo of mine to show.
I like the DR. Gas X setup, all these others are copies.
The X has to go behind the safety loop.
Old 01-29-2014, 05:39 PM
DBasher's Avatar
DBasher DBasher is offline
Learn something new everyday. Let me ask ya, if its mounted 6" off the front and the rear joint breaks would it hit the ground?
The only loop I've put on is our Studebaker and its more toward the rear. I know that where its located either end can break and neither hit the ground. Just curious.
Dan
Old 01-30-2014, 03:03 AM
67Rally's Avatar
Dan
Yes, it would still hit the ground, but it would just drag. I think the real fear is that if the front lets go, it could tear up the tunnel and anything (anyone) directly above it.
There's no reason why you couldn't run two loops. One front and one rear, but the NHRA rules require only the front one.
Old 01-30-2014, 09:10 AM
OBeer-WAN-Kenobi's Avatar
Originally Posted by 67Rally View Post
...I think the real fear is that if the front lets go, it could tear up the tunnel and anything (anyone) directly above it....
Not to mention, possibly pole vaulting the car ass over tea kettle.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-30-2014, 09:21 PM
intocarss's Avatar
SOME CARS IN NHRA REQUIRE 2 LOOPS
Old 01-30-2014, 10:31 AM
Ron Sutton's Avatar
Yup, yup. Agreed.
Ideally, the H and/or X pipes are placed at the optimum distance in the exhaust system to help relieve the "exhaust pulse traffic" to increase power. Of course packaging can be a challenge, preventing us from placing them at the optimum points. But if the H and/or X are placed too far from optimum, they will actually hurt power output.
Ron Sutton Race Technology
