Old 01-22-2014, 10:13 AM
GPR's Avatar
GPR GPR is offline
Default 1980 Z28
When this first came in we thought we could do a quick paint job, update the suspension and brakes make it a roller so the customer could install a GM crate engine. The owner bought it sight unseen but had it inspected. At first it looked great.
We removed the rear bumper and found this.
Cut out the first layer of rust
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 01-22-2014, 11:32 AM
Ricochet's Avatar
Ricochet Ricochet is offline
So this is why the Mustang is on the back burner!
What's the plan for this? How involved do you plan on getting with this one? Stock or modified?
Brent
Old 01-22-2014, 01:48 PM
GPR's Avatar
GPR GPR is offline
It will take me a little while to get up to date. Yesterday 6 piston 14" Baer brakes came in.
Rusty Gillis
Port Richey Fl
Old 01-22-2014, 02:55 PM
GPR's Avatar
GPR GPR is offline
One of the first things we did was install Global West subframe connectors
Rusty Gillis
Port Richey Fl
Old 01-22-2014, 06:01 PM
brownz brownz is offline
Thats a common place for rust on these cars
Old 01-23-2014, 08:07 AM
GPR's Avatar
GPR GPR is offline
The T-top channel had rust that Brian had to cut out and fabricate patches
Rusty Gillis
Port Richey Fl
Old 01-24-2014, 03:14 PM
GPR's Avatar
GPR GPR is offline
The owner ordered a DSE roll bar made for a 1980 Camaro.
Sanded and epoxy primed
Before installing the roll bar we had to patch a few small holes in the floor and sand followed by a couple coats of epoxy
Rusty Gillis
Port Richey Fl
Old 01-29-2014, 03:20 PM
GPR's Avatar
GPR GPR is offline
The right fender had rust in the brace plus a small spot on the fender. This is what it looked like under the brace.
The left fender did not have any rust showing but the owner wanted it taken apart and epoxy primed also.
Rusty Gillis
Port Richey Fl
Old 02-04-2014, 03:33 PM
GPR's Avatar
GPR GPR is offline
As we were taking the front end apart we noticed we had a rust problem where the steering box and sway bar bolted to the frame
Sway bar bolts
There was a lot of rust inside the frame
Last Friday a semi delivered this DSE powdercoated assembled hyrdoformed subframe with rack and pinion steering and coilover shocks.
Rusty Gillis
Port Richey Fl
Old 02-04-2014, 03:39 PM
mitch_04 mitch_04 is offline
Wow...those thing do not come cheap! Sure seems like it's being done right and then some!
