Old 02-06-2014, 02:39 PM
you were the inspiration for this car. The owner watched you plow through the autox on youtube and sent it to me. Nice counter swinging your turns BTW. thats old school.lol We are doing a tiny tub on it to fit 295's on 10's in the back.
Originally Posted by Bad94 View Post
Rod, that is a GREAT write up.
Not even at Ride Tech a week and already at it.
Those Forgelines look great on that car.
I know the Camaro and Novas are different, but I run 18x9.5" with 275/35/18 with complete Ride Tech set up. I ran the wheel/tire combo off the 48 Hour Camaro at RTTH's and they do fit.
Old 02-06-2014, 02:44 PM
Damn True's Avatar
Damn True Damn True is offline
Great looking No-Go [/hijack]
Old 02-06-2014, 09:12 PM
Rod P's Avatar
Rod P Rod P is offline
Thanks Vinny! that Nova is LOW!!!!! dang! show that micro tub install off
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-10-2014, 08:54 PM
glr0212 glr0212 is offline
Hey Rod,
What is the ride height measured to the top of fender on your 68? Is it also 23 3/8"?
Old 02-11-2014, 11:40 AM
Rod P's Avatar
Originally Posted by glr0212 View Post
Hey Rod,
I would like to measure it for you, but its 3000+ miles away from me right now
Rod Prouty
Bangshift Stories
Old 02-11-2014, 04:56 PM
liar, its more like 2465 miles but who's looking. : )
Old 02-11-2014, 07:19 PM
Rod P's Avatar
ha ha ha ha ha
Rod Prouty
Bangshift Stories
Old 02-12-2014, 08:14 PM
Buick Grand National Guy Buick Grand National Guy is offline
Default Detroit Speed Cars
Please note that you cannot compare wheel/tire setup on a car with DSE front subframe with a car with stock subframe! Reason is DSE subframe is designed to allow sharper turning radius by moving frame rails inboard. Splined sway bar is also designed to allow sharper turning radius. Result is ability to move wheels inboard for more clearance between fender lip and outside of the tire.
Conrad
Original owner of 1974 Z28. Ordered car with 4 speed, LT, Air Conditioning. Numbers matching car. Now equipped with Edelbrock Pro Flow fuel injection, 96 Zette Wheels, B-Car front disk, WS6 rear disk.
Also original owner of much-modified 1984 Grand National. Ridetech front & Detroit Speed rear control arms/sway bars Ridetech 3-way coil overs. Champion aluminum heads & intake. Comp roller hydraulic cam. CF hood, fiberglass bumpers. Baer 6P (2-piece rotors) 14" front & 13" rear brakes.
Old 02-13-2014, 11:10 AM
Conrad,
Clearly dse is a in a different class of suspension upgrades but the point is they gave themselves more than an 1.5 " clearance to the fender when they designed their subframe. If you want a no compromise setup to fit a 275 tire ridetech is not quite that.
