Old 03-02-2014, 03:28 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Ummm, YES! I'm running a Moser floater. I have about 5000 street miles with no issues at all. The only installation issue I had was that no one sold a weld on brake caliper mount so I had to fabricate my own.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-02-2014, 07:35 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Couple ?'s. Do you know what the bolt circle/pattern/bolt size is on the rotor adapter to hub attachment point. Also, would you happen to know the inside diameter of the snout/spindle? Trying to figure out if my fixture bar will slide through these Moser DBP snouts..... also seeing if my rotor adapters will fit these hubs.....
Thanks, Jay
Old 03-03-2014, 06:28 PM
TheJDMan's Avatar
Jay,
I do not know the rotor adaptor to hub bolt circle. I used the Moser supplied adaptor but I did have to find a source for the rotor it's self. The rotor mount is 8x7" but I needed a 1.1" thick x13" dia rotor for the C6 calipers so I had to have a pair of custom rotors made 1.1" thick to fit the 8x7" mount. Interestingly, the custom rotors were cheaper than standard Wilwood rotors. As for the snout ID I never measured it but a Ford 31 spline axle will fit through it if that helps.
PS. If anyone needs a source for custom rotors I purchased them from Coleman Racing.
http://www.colemanracing.com/Default.aspx
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-03-2014, 07:15 PM
Jay,
Thanks for the reply. I actually called Moser and they informed me of the 1.381" i.d. for the snout and then I forgot to ask about the bolt circle on the rotor adapter to hub pattern but thanks again for the info. Your car is looking TUFF!
Old 03-04-2014, 03:23 PM
eric1967 eric1967 is offline
I just purchased a Moser floater. Just getting it installed & have not driven it yet. I do have an issue with the cap that covers the axel & mounts to the drive plate is hitting the center cap of my wheel. It has a socket head cap screw. I believe I can use a flat head & counter sink it to gain about 1/4" of clearance. If that does not work I will machine a new cap with added clearance.
Thanks Eric
Old 03-05-2014, 01:09 AM
ADiCarlo ADiCarlo is offline
Jay,
Do you know what your WMS is? Did you use an off the shelf unit from the website or do you have them build it?
Old 03-08-2014, 07:06 PM
TheJDMan's Avatar
I custom ordered my axle from Moser with a 57" WMS dimension. It was the same price and in fact they require you to specify the WMS dimension when you order.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-09-2014, 05:44 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
I'm running the Moser setup in my Mustang. The only advise I would give about ordering it, don't have them put a back brace on it. Mine showed up I put the brake brackets on it, painted it and put it in the car. When I drove it I could tell something was wrong, but on the trailer it went to the Motorstate Challenge. It was a spinning out machine, spun out like 3 times. Come to find out when they welded the back brace on, they warped the housing. 1.5 degrees toed out. Pulled it, sent it back, they did straighten it at no charge, but I did have to repaint it. Really cheesed m e off that they didn't check it first. Mines been OK since, also make sure you have them turn down the drive plates to chevy diameter or your wheels won't fit. I did fab a bracket so I could run Baer brakes with the emergency brake.
Old 03-09-2014, 06:18 AM
Nice work on the parking brake setup.
Old 03-10-2014, 04:09 PM
Definitely all worthwhile info.
I planning on running an in-line hydraulic e-brake seeing that the floater set up typically doesn't support a standard brake shoe set up.
TheJDMan - Are you mini tubbed and do you mind sharing your wheelsize/backspace? You've got a killer set up!
