Old 03-04-2014, 08:49 PM
NvrDun71 NvrDun71 is offline
Its a swedge fit.
You can cut it out and tac weld a 3/8" bolts back in.
Appreciate the info. By cut do you mean drill out? Was hoping there would be other alternatives rather than the welding in a bolt method, but that may have to do
71' Nova - LY6, T56
Old 03-04-2014, 09:13 PM
Sieg's Avatar
Sieg Sieg is offline
There are alternatives......but why? Grind a flat on stud with a die grinder, center punch it, then drill it out. You could use a flat head bolt but technically it's weaker and more expensive than a grade 5 or 8.
Old 03-05-2014, 12:11 AM
you could always put it in a box and ship it to me and I could fix it for you.
