Old 04-05-2014, 08:43 PM
gerno's Avatar
gerno gerno is offline
I like the look of that panel Steve.
Thanks. They are simple but look much better than the log ones. They are also flat so there is room to add some lower bars on the roll bar I have as well.
I continued not he rear seat closeout today. I decided to grab some 1/2 sq tube and build up a structure to lay the ABS on. The whole structure will be bolt in in cans I need to access something. I'm pretty happy with the results so far. I wish the metal supply house was open today because buying steel at Home Depot is such a rip off For now the ABS will be flat panels using 1/4" cap screws with washers to add a little flare. If I decide to do the side exhaust the panels will stay flat. If I decide to exit the exhaust out the back I'm thinking the battery can go in the rear section and I can build out 2 storage compartments in the front.
Old 04-05-2014, 10:25 PM
Now that looks great too. What ya gonna hide under there?
Old 04-05-2014, 10:44 PM
side exiting exhaust......
Old 04-05-2014, 10:59 PM
at least that...
Old 04-05-2014, 11:09 PM
Track Junky's Avatar
Yup
Gaetano Cosentino
Old 04-06-2014, 08:46 AM
gerno's Avatar
Still not sure on the side exit, cutting out the floor and getting back together cleanly is my issue. If I don't do the side exhaust I'm thinking to raise the floor ~2" with a flat piece of steel (thinking 18 or 16 ga) for both muffler clearance under the car and also a clean place to mount the battery
Old 04-06-2014, 08:51 AM
Take it over to Eric and have him bead roll some pattern into it - or be sorry.... it will oil can if you don't put some structure in to a flat piece.
Old 04-06-2014, 09:22 AM
gerno's Avatar
You think even the 16ga will flex/warp? I was thinking it was thick enough to not have an issue for the ~12"x12" piece that would go in the floors.
Old 04-06-2014, 10:13 AM
No 16 would be fine --- I thought you were cutting out more of the floor than that.
On my buddies '55 that I built -- I simply pie sliced his rear floor foot well --- and moved it up an 1" and welded it back together... gave me enough room and some clearance for his mufflers.
Old 04-06-2014, 12:19 PM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
Update on the wheels. Travis received them yesterday morning. I was shocked how quickly he adjusted the bore and added a much large chamfer to the end. I had UPS tracking information by ~3PM the same day. If all goes well with the shipping I should have them back on Friday. I have to say the service from Travis was awesome.
I can't wait to get them back up have a lot of stuff left to do. It's going to be a busy weekend.....
Steve,
Wheels, tires & stance look great! Thank you for choosing F43 wheels, enjoy!
