Old 03-22-2014, 10:24 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
All caught up reading from the past year of post. Great work and I dig your son's pull behind project.
Old 03-29-2014, 09:15 PM
frankv11's Avatar
frankv11 frankv11 is offline
Tx brett
Brown truck dropped these off.
Got firewall done " again " minus a few holes. AC fits in perfect. Clutch bracket is set. Cut trans cross member a bit. Looking for a good entry location for engine harness and battery cable. Put it all back together to double check clearances.
Old 03-30-2014, 03:40 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
looks great Frank,time for some paint
Old 03-30-2014, 01:03 PM
It looks good! Love That Brown Truck!
Old 05-01-2014, 07:52 PM
frankv11's Avatar
far away from paint that will be stage two. the plan is to build it completely drive it bare bones tweak ,add, subtract, cut etc.. and blow it completely apart go through every piece in more detail and hopefully final assembly.
love the truck, don't like credit card statement !!
Old 05-01-2014, 11:26 PM
frankv11's Avatar
So I got a bunch of other stuff done . Centerforce aluminum flywheel and dual friction clutch is done , mastmotor sports oil pan is in , oil filter relocation unit from JCG ( tx Chris ) .filter& AN oil lines done , power steering lines ( tx XRP ).
AC and heater lines , ran and plug harness to make length adjustments , built a cool bracket and location for + power block. Built aluminum close out panel to match passenger side, it also holds AC dryer. Upgraded to carbon fiber SC shaft and smaller pulley, AC condensor is done , heat exchanger clerance position and mods done , building an expansion tank from an old AC dryer.
Hope to get accurate oil pressure reading on this
Was able to squeeze this guy in there ( tight fit with headers )
Those two screws will get deleted. Got a miller spoolmate can't weld but can tack. Will send to a buddy for tig ( make it pretty )
Pile of hoses
Got these new inner fenders from Ron in SoCal ( tx )
And this is what happened to mast's oil pick up. It hit the oil pan in about 4 different points & flange @ oil ring would not sit flush. So it needed a half a day and some begging
As you can see it still needs a ton of organizing wires etc.... And will get rid some bling, radiator , condensor , heatexchanger , intake basically all aluminum pieces with get anodized, minus SC - would like to but it's to much work to gutt it out.
Old 05-02-2014, 01:11 AM
tubbed69's Avatar
nice work as always Frank
Old 05-02-2014, 07:58 AM
fleetus macmullitz's Avatar
Agreed.
Old 05-02-2014, 08:30 AM
syborg tt's Avatar
I agree - very nice
marty-mj
Old 05-02-2014, 09:28 AM
Ron in SoCal's Avatar
Originally Posted by cosmo meant it View Post
Agreed.
I agree - very nice
Way to go Frank!
Ron in SoCal
69 Camaro in progress
