Old 05-29-2014, 12:50 PM
89 RS's Avatar
89 RS 89 RS is offline
This is going to be a cool project, look foward to seeing more!
Corey
1989 Camaro RS
Old 05-29-2014, 07:52 PM
Thanks for showing that, Vince. I had in the back of my mind that some room to go lower could be obtained bu removing that portion of the inner tub but just hadn't looked into it. I might have to when I go to do quarters on my TA since I want to be low.
Old 05-30-2014, 01:04 PM
kttrucks's Avatar
kttrucks kttrucks is offline
Vince, You're right... I know it. Even to have the room and not use it right away, and perhaps later just switch to the DSE offset shackles to add wheel & tire will be MUCH less hassle than tearing the car down to tub...Thanks for the nudge! Now that the body is on the rotisserie it'll be less work as well.... I'm just following a low-buck theme and I honestly didn't think about whittling them down, adding a filler strip, etc.... Typical, there's more rust in the floors than I had hoped, but the frame rails and braces are all OK enough not to have to replace.
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
Old 05-30-2014, 02:43 PM
As long as your frame rails are good you are golden!! The way I see it, bad floors = more room for exhaust.
The 2nd gens are easy to low buck tubs.
Trace 2 1/2" outside from your existing tub and make a nice cut.
On the body side, just cut along the vertical lip, clean up the tub. Remove the old floor from the tub.
Cut a 3" new filler section to mirror the body side of the tub you cut ,tack it on the tub and the outer edge gets welded to the outer wheel house horizontally. Quick and easy. Add a vertical filler to the frame side and your done.
Old 05-31-2014, 01:33 PM
kttrucks's Avatar
Cool! Thank for the tips... the only thing missing are pictures for the instructions... I guess that's my job now.
I appreciate the though and help!
KT.
Old 05-31-2014, 07:35 PM
KT.
shoot me your email address, i'll send you a bunch....
anytime, I enjoy sharing what I have learned over the years.
CURVES's Avatar
CURVES CURVES is offline
There is a little fly in your ointment......
If you tub, don't forget about shock relocation!
The tubs tend to start a bit of a snowball, didn't stop me though
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 05-31-2014, 07:37 PM
that should be cake for a truck guy. you know where they go.
