Old 06-12-2014, 05:24 PM
Ever consider e-stopp electric brakes?
Www.estopp.com/
Old 06-12-2014, 05:37 PM
69greyghost 69greyghost is offline
Originally Posted by geberhard View Post
Anthony, contact Jim. I posted on norcal and he will do the full install for $400 labor including his trip what is not a bad deal and he does great installs. I will text you his phone.
I woudl say do not despair! Do you have the small e-brake metal brackets that hold the line on the axle?
Again if the only need for the e-brake is for parking purposes the simplest approach is a hydro lock setup inline, plus great theft protection as well.
Gui
I dont have the small brackets that hold the lines, do you know where I can get that? Whats hydro lock and how do I do that?
Www.estopp.com/
I looked at them and they were kinda pricy, are there any other options?
Old 06-13-2014, 10:52 AM
geberhard's Avatar
geberhard geberhard is offline
Vince I dig the electrics, but only issue with them is they draw power so if the bat disconnects or charge drops, they do not work too well.
I would go with a line lock hydro type than electrical for the reason above. I have run them on rock crawlers and they are fairly simple, and you can go as fancy as you like with cutting brakes, swage locks, etc.
Anthony, from your text, basically they run about $30 bucks and up, to operate:
1- just push your regular foot brake pedal (to clarify not e-brake pedal), and hold.
2- press button on line lock (if electric) or turn handle
3- release foot brake.
4 - you are now locked
pretty simple pic and link below goes into a lot more detail.
this i what a manual type looks like:
electric type:
http://www.jegs.com/i/JEGS-Performan...63003/10002/-1
basic diagram:
http://www.maliburacing.com/linelock/linelock.htm
hurst setup is pretty cool:
http://www.jegs.com/i/Hurst/530/174-5000/10002/-1 (check the instructions tab)
Again this is a pretty simple approach, works pretty well to use as a e-brake and theft deterrent (plus front dig for burnouts )
Gui
Old 06-13-2014, 10:57 AM
geberhard's Avatar
Another:
http://www.lowrangeoffroad.com/index...line-lock.html
