Old 06-15-2014, 04:04 PM
malibu795 malibu795 is offline
Originally Posted by 214Chevelle View Post
I say LS7, 427. I'm going LS7, 427 myself with a wet sump. And $13k for diesel rotating assembly...that'll be a negative for me. May be a cool engine, but I'll pass. Lol!
but you will drop ~20k on an engine? sorry had too lol
http://www.mastmotorsports.com/view.php?id=155&c=4&s=6
FWIW
~20k will buy used dmax, rebuild (non 427 stroker kit), install and have 1000-1200hp with supporting fuel and air.
~7k can do a repower and be around 650-700
Adam Wildman
99 C3500HD dmax/4l85E
79 malibu wagon 468bbc/ t-56/8.8
U.S. Navy 2000-2008
Old 06-15-2014, 05:57 PM
Go wet sump LS7 and get yourself that 427 you've always wanted.
Old 06-15-2014, 07:05 PM
Che70velle's Avatar
FWIW
Marcus wished he "only" had 20k in his engine.
Comparing diesel torque numbers to LSX torque numbers is foolish. And those guys making those kind of HORSEPOWER numbers, Not TORQUE numbers, have pulled out a second mortgage on their farms. The supporting systems to make that happen is BIG MONEY, but I guess an 8 second diesel is cool...
RBuhr69, if money isn't a determining factor for you in this hand, I'd easily go with the LS7, no question. The Mast guys are the real deal. Damon has helped me out a ton, and they always go out of their way for you.
Thanks Dad!!
Old 06-15-2014, 07:36 PM
is it cheap..... NO.. none of this stuff is "cheap"..
1000hp diesel is darn near a you need A, B, C parts and a good tuner. engine, turbo, fuel parts can be had for ~20k labor not included
beating up on gas engines like audi does at the leman with a diesel is definitely cool and different..
i'd side with the LS7 over the LSx
got to pay to play right?
Adam Wildman
U.S. Navy 2000-2008
Old 06-16-2014, 12:15 AM
kiwigt kiwigt is offline
There is something special about a 427 for me. Katech converted my LS7 to wet sump, and added their Torquer 110 cam and CNC heads, dyno'd at 610hp, 570 ft lb. But people talk about the 'LS7 tax'...and it is real. Got to pay to play.
Old 06-16-2014, 01:00 AM
Bmf5150 Bmf5150 is offline
Wouldn't you be better off with a lsx427 than ls7 short block.much stronger
Old 06-16-2014, 04:28 AM
Che70velle's Avatar
If boosting is in your future, then an iron 427 is the way to go. The weak link of an ls7 is the cylinder wall/ block support gets thinner, due to the larger bore size. I would not boost a stock GM ls7 block, but I'm not sure the OP wants to boost this engine.
Some of the early ls7's had valve issues, but that's not an issue with the mast black label heads.
Thanks Dad!!
Old 06-16-2014, 04:54 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Excellent feedback guys, I appreciate it......... all roads are pointing to LS7 as that is what I have always wanted. So its time to do the right thing and pony up for the LS7 versus the LS3 even though I know the LS3 will suffice. Now I wont worry about kicking myself and not getting what i wanted.
No boosting for me, straight up motor.......
thanks for all the input!
