Old 06-17-2014, 07:45 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by 71RS/SS396 View Post
We can build you a 427 with LS3 heads....
Kurt, I'm building an LS7 with LS3 heads because I'm using a Kenne Bell supercharger and that's what manifold it uses. But, as the OP stated, he isn't going to supercharge his engine. So, my question is, wht reason or why the LS3 heads instead of the LS7 heads on an LS7? Now, I do know, essentially that all 427's aren't LS7's, but I'm just curious as the OP stated he was leaning towards an LS7.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-17-2014, 08:01 AM
71RS/SS396's Avatar
This isn't Kurt (I'm Tim) but I work with him daily. The reason for the LS3 heads is... there are far more intake manifold options out there for LS3 heads should someone want to run something different vs the vary limited choices for LS7 heads.
Old 06-17-2014, 08:50 AM
214Chevy's Avatar
Thanks Tim. I now see your name "Tim" in your signature. Hahah!! I just wanted to know becuase I see alot of people using LS3 heads on 427. Can you pm me a cell or contact # so I can call you about some options?
'68 C10 swb
'72 Chevelle
Old 07-10-2014, 09:31 PM
Gas Huffer's Avatar
Gas Huffer Gas Huffer is offline
Saw this thread good luck with you choice Im sure you will get a killer motor no matter which way you go.
check out our street and show series line up:
http://www.gashufferhotrods.com/category-s/1817.htm
We got both options for ya!
Old 07-11-2014, 01:01 PM
Dasilva motorsport built a Z06 with a charger and a stock intake manifold, now it did have a cam swap and some head work but it put just shy of 1000 hp down at the wheels. They are the LS gurus lol. They're doing my motor for me I was told to expect 630-650 then got called a ***** for so little power lol
