Old 06-17-2014, 07:23 AM
Ron in SoCal's Avatar
Originally Posted by Lenie View Post
Now that's funny Matt! Ron, the car's looking outstanding. Can't wait to see it in person, congrats!
Thanks Lenie! I'll be doing lots of NorCal stuff and hopefully you can come on down
What's wrong with the steering? Wheel clocking or other?
Yep Vin, that's what I was calling you about. It's a combo-cluster of steering stops, tie rod adjustment and PS resi to cooler height. I'll get it fixed!
Originally Posted by OBeer-WAN-Kenobi View Post
Other..... *Hint* the problem is sitting aft of the wheel.
Yep OBWK, it's that wing nut behind the wheel
Ron in SoCal
69 Camaro in progress
Old 06-17-2014, 10:28 AM
C5 spindles....make an adjustable steering stop. easy, unless your steering arms are hitting, then not so easy.
Front steer so if your wheel is left 1/8" and steers straight...mark your tie rod sleeve with white out....make the left 1/2 turn longer, make the right side 1/2 turn shorter. Fine tune it but do not change the difference in relation to each other. You are going straight. Easy, if you take your time and remember what you do.
Cooler is on the return right? Are you getting aeration? Ideally, the reservoir should be the highest point to trap and release air. Are you certain the hoses are on correctly. Matt can attest to that.
Old 06-17-2014, 03:44 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
I don't see what the problem is Ron, steer by rear, steer by rear
Old 06-17-2014, 06:02 PM
Is this thing on the road?
Old 06-17-2014, 08:47 PM
Back at BOS, somebody sneezed on it at the car show.
Old 06-17-2014, 09:48 PM
^ Brothers from another mother
Found this on FB
Ron in SoCal
Old 06-17-2014, 10:20 PM
Why would you need tools???
