Old 06-26-2014, 09:37 PM
Ron in SoCal's Avatar
Originally Posted by 69x22 View Post
Cool!!!
Thanks man. Your car is an inspiration
Joking aside for just a few minutes, it really is refreshing and long awaited to see Big Bad Ron post a video putting his 69 through the paces. Wish I coulda been there.
It's just the beginning.
Thanks Davey!
Originally Posted by Greg from Aus View Post
Great to see Ron, Now get it all sorted so I can pick your brains.
Already working on it Greg. Spoke to RS today
Originally Posted by efs69 View Post
Good to see you got the car out and are putting it through its paces. I can relate to the driving part but that will come. In regards to the steering could there be some debris in the pump? I would take the valve out and flush the system. With new stuff there is a possibility of some casting fragments getting loose and mucking it all up.
Possible Efrian. I think I started off on the wrong PS foot and need to get back to level ground. I'm calling you to go with me the next track day.
Originally Posted by tones2SS View Post
So awesome Ron. Glad to hear the car is running well and that you're enjoying it.
Keep it going bro!
Thanks Tony! Appreciate the kind words, as always.
Ron in SoCal
69 Camaro in progress
Old 06-26-2014, 11:43 PM
ironworks's Avatar
Thanks for the suggestions gentlemen. Here's my plan - first I'll verify that Wegner sent me the correct flow rate pump for my DSE rack. I have a GM pump on the shelf (go figure) that is supposed to be matched to the rack so I can swap it out to test. I'll also remount my cooler lower. I've heard others with the same problems with this rack and I'd rather not put a three foot hose in the engine compartment (great suggestion though Rodger). If there's any lingering issues or notchy-ness I'm replacing the rack and getting a matching pump. I've also got a valve for the pump that'll match the AGR so one way or another this will get fixed.
Appreciate the input for sure
You crack me up Ron. I did everything you said. Changed 3 pumps, the 3rd being a bad ass 600 dollar KRC pump. Changed reservoir changed to GM fluid and the only thing that fixed it was the hose. Oh and I spent a stupid amount of time researching. But if you don't want to clutter up your engine compartment cool.
I have some pumps and reservoirs in the for sale section I will make you a deal on.
Old 06-27-2014, 12:26 AM
Glad I finally got you to bust a smile Rodg, lol. At what point did you dump the rack?
Serious question though, how the heck did you figure out a longer hose might be the fix?
Ron in SoCal
Old 06-27-2014, 12:37 AM
Sieg's Avatar
Sieg Sieg is offline
Coil the hose.
Old 06-27-2014, 07:39 AM
DOOM's Avatar
DOOM DOOM is offline
Ron I really love seeing the car out doing what it was built for !
Mario
USCOLLISION
Old 06-27-2014, 08:25 AM
ironworks's Avatar
Oh I forgot I swapped that also.
One of my customers has a flow issue on a Steam Generator with a variable displacement pump at the exact same time.
I'm going to guess your pressure line is less then 10 inches. If you think about OEM pressure hoses they are pretty long for the actual short distance that the fluid needs to travel.
Just swap the hose and if it works you can send me a big for saving you all that time and money. And if it does not work feel free to bad mouth me on the old interweb.
Old 06-27-2014, 11:00 AM
frankv11's Avatar
frankv11 frankv11 is offline
remove and replace until you fix it. I'm wondering if you need more volume moving through there, maybe you need a restrictor valve with bigger opening
Old 06-27-2014, 01:32 PM
Payton King's Avatar
Too much flow will mess up the spool valve and/or make the steering too light. Bypassing too much fluid with the restirctor will cause the fluid to over heat as well as aerate. Making the power assist sporatic at best.
I had my pump rebuilt by ARG to match the flow of my rack. They also fluted the vanes so they would not foam up the fluid.
They changed the torsion bar size in the pinion valve to improve the feel.
Here is a link, go the the middle of the page
http://www.agrperformance.com/Hot-Ro...erformance.htm
All of this may have been done to your stuff, but this is what I had to do the the yellow car when it was first completed many moons ago.
Old 06-27-2014, 07:12 PM
Ron, Do it the hard, expensive way.
No, it hasn't been long enough to wax the car for the first time.
Old 06-27-2014, 07:36 PM
Was there ever any doubt?
