Old 08-11-2006, 08:08 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Official press release: https://lateral-g.net/forums/showthread.php4?t=5563
I can't wait .
David
Old 08-11-2006, 11:27 AM
T Bell T Bell is offline
Originally Posted by trapin
Because the vehicle is being packaged around the V8. The V8 has four cylinders longitudinally. I6 obviously has 6. Adding a clylinder to the length of the engine automatically pushes everything forward 100mm which means the I6 would move everything forward 200mm. This of course must be made up in either the wheelbase of the vehicle or it's front overhang which eventually impacts the vehicle's overall length. 200mm might not seem like much but you add that to the concept vehicle in the wheelbase or on the nose and you're going to notice it right away. It's a safe bet that that wouldn't fly with Styling.
well if anybody wants to trade my I6 out of my Cherokee for their LS6 or 7, I would have no problems. You can actually make alot of power on stock internals of inline motors as opposed to V series because the pistons are all pulling in the same direction and not against each other.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 08-12-2006, 08:39 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Great points, Tony. The styling on the car is brilliant and I wouldn't mess with an inch of it, especially adding an ugly overhang. Thanks for the insider explanation.
I knew I was dreaming but that I6 is such a cool motor, I'd love to see it pumped up a little and put in a performance application because they already make 280 in a plain jane Trail Blazer.
That's a computer adjustment from 300 N/A hp.
Old 08-13-2006, 12:18 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Agreed- The 06 4.2's make 291hp stock, with a torque curve flatter than Florida. These engines are basically a large-displacement Ecotec, although they have different lineage (they do share valvetrain components). 300hp in Camaro-tune would be no sweat. But, as stated- they just wont fit without a bigger compromise than they are willing to make. Bummer.
Mine is going to make north of 850hp with a stock (mod'd) crank. There are Comp Elim guys running these with carbs making 550-600 N/A hp, spinng 8600-9Krpm.
But I'm biased...
Old 08-13-2006, 07:59 AM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
what is the price tag, has it been said?
Old 08-13-2006, 08:25 AM
i really hope the interior looks like this!!!!!
Old 08-13-2006, 06:22 PM
trapin's Avatar
trapin trapin is offline
Those I5's aren't bad motors either. I drove my neighbors Colorado the other day and I was impressed with the torque and performance. My wife has an I6 in her trailblazer. That too runs real good.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 08-14-2006, 05:34 AM
tumper93 tumper93 is offline
The bad thing about the camaro is that as it sits now it is on a CTS chassis and GM is being required to redesign it because of poor crash test rating. The Camaro will come out but the current suspension and driveline will change and knowing Gm the body as well.
