Old 08-15-2014, 10:53 AM
Originally Posted by dhutton View Post
They are secure. That type of fitting is widely used in other applications. I have used them several times without issue.
They are designed for aluminum tubing but I have used them on transmission lines (90 psi dead head pressures) and mechanical fuel pump applications with steel line with no issues. Whether it works with the harder stainless line is what is not known. 70 psi fuel pressure you gonna wanna flare the tube.
Any particular reason you are wanting stainless? 1/2" stainless isn't a whole lot of fun to work with.
Old 08-15-2014, 11:53 AM
Musclerodz's Avatar
That is a compression style fitting. I am sure they work fine, but not what I prefer to use.
Mike Redpath
Musclerodz & Customz
facebook page
