Old 08-22-2014, 07:15 AM
captainofiron's Avatar
captainofiron captainofiron is offline
Do you run a sway bar with that 4-link?
Also seems like with teh coil overs, it would be easier to put in mini-tubs
Old 08-26-2014, 05:24 PM
Bad94 Bad94 is offline
I have the Camaro rear bar on mine.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 08-26-2014, 06:27 PM
ma73z's Avatar
ma73z ma73z is offline
I just put the ridetech 4 link in a 69 firebird over the weekend and am super happy so far! If I didn't already have suspension for my 73 it would get it also.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 01-03-2015, 09:02 PM
Pete68's Avatar
Pete68 Pete68 is offline
Leaf spring is about the worst suspension for performance thats why only pickup trucks use them today. They are super heavy so unsprung weight is bad and there is nothing it keep them from shifting side to side like on a 4 link or even on the previous mustang with the solid axle that had the panhard bar to keep the axle from moving. Automakers used them because they were cheap.
Just find a stiff leaf set up and put in a rear bar and go with it.
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
Old 01-03-2015, 09:43 PM
Rod P's Avatar
Rod P Rod P is offline
I have used both leaf springs and 4 links, they both achieve the same result, ....just most don't tune leafs, ride heights, sway bar, adjustable shocks, anti-squat, swivel bearings....and so on, most people just bolt them on add a cheap $50 shock and wonder why the car doesn't handle
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-27-2014, 07:23 AM
cool, thanks!
Old 08-27-2014, 03:42 PM
Rod P's Avatar
run the sway bar if you have a wide 315 or 335 tire if your running a 275 rear tire the sway bar isn't as necessary...it can make the car loose
Rod Prouty
Bangshift Stories
Old 08-27-2014, 06:01 PM
chetly chetly is offline
Loose is fast and on the edge of out of control...
Old 08-27-2014, 07:57 PM
Rod P's Avatar
ummm...no
Rod Prouty
Bangshift Stories
Old 08-27-2014, 10:45 PM
DBasher's Avatar
DBasher DBasher is offline
So I only know what I've seen, that being said, Danny Popp is almost out of control, looks loose and hauls ass.
On the other hand maybe the cars so tight he's on the verge of being out of control, either way he hauls ass.
Hope that helped, haha!
