Old 09-10-2014, 05:44 PM
358Mustang 358Mustang is offline
I am at 18x12 front w/ 7.5 BS and 18x13 rear w/ 8.5 BS.
Front TREAD width outside of tire to outside of tire is 75 or 75.5 if I recall.
Um... did you mean Infineon is for corporate weenies?
Now, let's see that hat!
Ok nice. Pretty deep BS, I was doing some rough numbers with the spindle/hub setup I was trying to use and I was coming up with about 9" BS if I wanted to target 0 scrub... That seemed pretty high, I am looking into other spindle/hub options currently. I don't think what I have is going to work out too well... Too much SAI and the hub offset is pretty big.
Old 09-10-2014, 07:33 PM
chetly chetly is offline
Maier has some aluminum spindles with steel shaft that uses big bearings. They might work for you...
Old 09-10-2014, 10:06 PM
Payton King has the same size wheels and long arm deal but a .25 inch more BS so he closer to zero scrub than I am but neither of us are at true zero. Still pretty low and wide though.
Old 09-10-2014, 11:36 PM
I gotcha. Not sure how important it is, or if having an inch or so of scrub isn't particularly a bad thing then maybe I shouldn't sweat it. I just would rather try and do the figuring out now and optimize what I can (or at least what I think is right) rather than just compromise and call it good enough
Old 09-17-2014, 10:34 PM
SO now I am working on just making my own spindles. This seems like the best route for me, since I can dial in exactly what I want. I found some photos of some of the Trans am spindles, I plan on using a similar design. Mono ball upper/lower joints. Ive got speedway engineering 5x5 grand national hubs and coleman sells a weld on spindle pin that I am going to start building off..
Here is the spindle I was going to steal some ideas from and build it similar to this guy.
Id like to end up in the 6 degree KPI range and zero (or less than an inch) of scrub with an 18x11.
Old 10-12-2014, 05:39 PM
Made a little progress. Made a motor plate and got that tacked in. I needed to set the motor where I wanted it, next I plan on building the "sub frame" for the lower control arms. I think I am getting things figured out. I know I am 7" back from where my old motor was. And I had my old motor 2-3 inches back. So I'll call it 10" set back. Unsure on the height but the engine is very low in the chassis. I think I should be ok with pan clearance, but I have already explored some options of making a pan about 1-1.5" shorter if I need.
I'll have front and rear plates, as well as a tranny mount..
Old 10-12-2014, 05:44 PM
dstryr dstryr is offline
You made the engine plate? LOL
Dennis
www.creationsultd.com
1969 Chevelle Build - Meanstreets Performance Style
https://lateral-g.net/forums/showthread.php4?t=39456
Old 10-12-2014, 05:48 PM
If you closely interpret my posts. I said... "made a motor plate" .That could mean I made it, some kid in china made it, or in this case you cut it for me. And did the high quality programming
