Old 10-19-2014, 11:23 AM
Sieg's Avatar
Sieg Sieg is offline
Definitely not a car for mere mortals!
Want to see lap times with Hoosier's!
........and some details on the dashboard.
Insert quotes from Miata driver here:
Old 10-20-2014, 12:33 PM
dontlifttoshift's Avatar
http://www.race-technology.com/dash2_8_940.html
I want to see the run files.
Donny
Old 10-20-2014, 12:45 PM
Stielow's Avatar
Stielow Stielow is offline
I can log all the CAN data (Engine Information) out of the ECM. It also allows me to set warning lights for all the critical systems:
Engine Water Temp
Oil Pressure based of engine RPM
Oil Temp
Fuel Pressure
Super Charger Air Temp
Knock
Air Flow
Boost
I like it becuse you just have shift lights and warning lights. I can watch it out of the corner of my eye and not have to scan 5 gauges for problems.
It will also display lap times if I want it to.
So far it is cool. It has an Odometer, turn signals, high beam and park brake lights built in.
Mark
Old 10-20-2014, 03:14 PM
Sieg's Avatar
Thanks Donny
Old 10-20-2014, 05:27 PM
PTAddict PTAddict is offline
This is just an amazing car. It makes me wonder, where can it go from here?
I'm in this hobby because of you, Mark. It definitely isn't your nature to promote yourself or your role in this hobby, but the truth is that you had a clear individual vision that started with Tri Tip, and that vision engaged the minds of some other key folk, and together a movement was built. If you want to think of it in corporate terms, you were and are the Chief Engineer and Technology Officer. Jeff Smith is SVP of PR. And the CEO isn't one person, it's the community: the forums like Pro-touring and Lat-g, the many small/medium businesses like DSE, Ridetech, Wilwood, etc, and the individual craftsmen who raise the bar every year. What a force this movement has become.
For me, the Red Witch cover story in Hot Rod in '96 twisted a couple of threads together for me - the thread that never got over my first ride as a nine year old in a muscle car in 1969, and the thread that appreciates modern engineering, performance, convenience. I've followed every build closely since, and much of what I learned is reflected in my latest car.
I think the most interesting thing I take away is your approach: build, learn, refine. The biggest mistakes I've made, and that I see others have made, are to shoot for the moon before achieving orbit. Your approach always seems to be: Let's start with what is proven. Decide what are the priorities for improvement. Take risks only for the highest priority items, and then research those risks as thoroughly as possible. Build and test in the real world. Rinse and repeat. It's a formula we would all do well to follow - at least if real world results are the criteria. If I'm not mistaken, it's the formula that ultimately built this ultimate car.
Best of luck at OUSCI!
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 10-21-2014, 08:37 AM
syborg tt's Avatar
Mark,
I was going to type up pretty much what Scott just wrote but honestly he said it much better then I could have ever said it so please pretend I just wrote what Scott did. I will add this you and your team are truly inspirational.
marty-mj
