View Poll Results: What's your trans
TKO-600 42 45.16%
TKO-500 1 1.08%
T56 42 45.16%
4 Speed 8 8.60%
Voters: 93. You may not vote on this poll
Old 08-26-2006, 11:00 AM
rocketman's Avatar
I would skip the TKO 600,they are hard to shift,and I don't think they are tuff as everybody thinks.I have one in my 69 vette,that is crap I sent the first one back because you had to almost beat it in to gear.the 2nd one is a little better but still hard to shift.There syncorizer's suck.I am switching to a T56.soon as its built.
I have a D&D built T56 in my 94 z28 with a 600 hp lt1 and have had no trouble.And runs 9's on the bottle.
I recommend a T56 or you might checkout a Liberty 5spd,they are a clutchless style tranny.
Old 08-26-2006, 06:22 PM
fatlife's Avatar
fatlife fatlife is offline
Banned
Richmond 5/6 speeds will not live behind a motor like that. I havne't used a TKO600 before but I hear they are nice. I know for sure T56's are really tough. I have a D+D viper which cost $2700, but you don't even need that. You can find T56's used or fresh for under $2000, I see used ones for $1200, all you need is better synchros, and a steel shift forks, only like $300 worth of parts.
Old 08-27-2006, 09:48 AM
fatlife's Avatar
Banned
Not sure about that, I've seen plenty of 1000hp vipers and F bodies on near stock trannies running 9's. But beside that, I doubt in a protouring car that he is going to be hooking it up so hard he is going to break it. A 4-5000 dollar T56 isn't needed for 600rear wheel horse
Old 09-06-2006, 03:52 PM
Bandit's Avatar
Bandit Bandit is offline
Default Tko 600
From everything I have read and in talking to people, if the TKO 600 is hard to shift then it was probably installed misaligned, or some other serious problem. If installed correctly, these trannies shift like a dream.
My TKO-600 only has about 200 miles on it, and it practically shifts itself. The throws are short and positive, and it clicks into gear with no effort. In fact I would say that this is the sweetest-shifting tranny I have ever shifted!
And most guys say that they get even smoother after putting a few more miles on them. Can't wait to get mine completely broken in!
As for strength, I am told that these are some very tough trannys indeed. Tremec rates it at 600hp/lbs-ft, but a lot of guys are exceeding that with no problems. Some guys run 9 seconds in the quarter with 3500-lb cars using these trannies and the trannys just take it.
Paul
Old 09-06-2006, 11:12 PM
NEW NEW is offline
www.rsgear.com
I bought a "viperized" T56 for my 02 Camaro here, it works very well, after the install we put in a new engine which dynoed 596 whp, and 730 + nm on the wheels. N/a
I paid 2500 USD for that tranny,+ freight, it was a brand new unit. It has upgraded forks, carbon syncro rings, and viper output shaft, Opposed to the original tranny i think the upgrade was worth the money.
(i think they now offer the "transilla", t56 that stands something like a 1000 hp, and with options on pro shift, and custom gear sets,) i want one..
NEW
Old 09-19-2006, 07:03 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by NEW
www.rsgear.com
NEW
Search, "Tranzilla", T-56, on Google for information.
Old 11-15-2006, 07:59 PM
sikryd sikryd is offline
Buy a Turbo 400 and put in a manual valve body! That way you can have a trans that will live, and shift only when you want it to. Art carr makes some hard hitting manual valve bodies, just make sure you specify that you need engine braking in all gears, or you will let off the throttle and it will be like you are in neutral.
I would rather destroy a transmission than to have a panic stop and rely only on my brakes. I almost t-boned some dumb A$$ pulling an illegal U turn, if I did not have engine breaking in first gear I would have creamed him (dead for sure). I threw it in first at about 65 mph, rear tires locked up and I had to throw the car sideways. I hate stupid drivers!
Old 11-15-2006, 08:06 PM
ProStreet R/T ProStreet R/T is offline
Yeah cause a T400 has such a great overdrive
I've PERSONALLY put a couple thousand miles on a stock viper trans with the car making 800rwhp and it has never had a problem, including quite a few 200mph 5th and even a 6th gear pull.
Here is a viper running 8.75 on a bone stock tranny. http://www.heffnersperformance.com/v...8SECPASSES.wmv
Don't know how long it will live at that power level, but it did.
Old 11-16-2006, 02:12 AM
A Turbo 400 may not have an overdrive but it will out live any standard transmission when being raced. Let me see any standard trans that will not break when side steping the clutch at 4,000 rpm with slicks. Yeah, it may live through one, two, maybe 20 but one day.....BOOM! If you need an overdrive, there is always a gear vendors overdrive, then you have 6 gears with a Turbo 400. Come on, you all got butt loads of money in your cars right? Who cares about gas mileage! Not me....... And a auto will beat a standard everytime at the 1/4 mile, I don't care how fast you think you shift. (here's one back at you.......)
Old 11-16-2006, 02:34 AM
I think you're missing the point. He is not building a dedicated drag car which should be VERY apparent by the 6spd manual in it.
And sorry but ladder bars with a 3spd auto, and 4.11 gears would SUCK to drive around on a regular basis. All he asked for was how to get traction, not how to build the fastest 1/4 mile warrior possible. It's pretty clear this isn't a drag racing site, which leads me to believe he won't destroy the cars handling to gain a tenth. And eventually everything will break, so the whole it might last 20 or 50 runs is a moot point. After a few thousand miles of a T56 handling anywhere from 1050-1389rwhp on drag radials, well damn I think thats good enough for me. A couple well respected members here have been in the car and can vouch for it being insanely fast. If anyone was going to destroy one from gross abuse it would be me.
Oh and no an auto is NOT always the fastest at the track. Last time I checked the entire pro stock field was banging gears via a big liberty shifter, and there definitely isn't a converter in there.
I'm finished with this thread jack.
