View Poll Results: What's your trans
TKO-600 42 45.16%
TKO-500 1 1.08%
T56 42 45.16%
4 Speed 8 8.60%
Voters: 93. You may not vote on this poll
Old 07-25-2006, 10:17 AM
67SSChevelle 67SSChevelle is offline
Default Which manual trans with BIG power?
Just trying to get a feeler what tranmission you guys are using behind a motor that isn't quite stock. I'm using a turbo's LS1 making 650-700 at the rear wheels. It's not going to be a race car but who's to say it won't see a spirited drive now and then
Thinking the TKO-600 is my best bet
Old 07-25-2006, 12:24 PM
aonghus's Avatar
aonghus aonghus is offline
Depends, a T56 stock is only rated at 450 ft. lbs, unless you viperize the trans, which will cost around $3500 for the whole trans and reubild it probobly isnt worth it to you.
The TKO600 is pretty hard to beat right out of the box...
But, there is that sixth gear.....
Old 07-25-2006, 06:20 PM
hiwayman hiwayman is offline
yea man i just got the tko600 im sure the clutch is just as important i realy like the look of the mcleod soft lock system from what i can see it takes some power out through slipage with that much power i think you got plenty
Old 07-25-2006, 08:19 PM
nitrorocket's Avatar
Why not go auto? With that much power it will suck to try to go fast in. Auto is nice and easy.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 07-26-2006, 02:09 PM
tracy's Avatar
tracy tracy is offline
You can buy a viperized t56 from D&D performance for under $3000. I know since I did.
Goodies Speed Shop
Old 07-26-2006, 07:46 PM
novanutcase's Avatar
Default D & D
Tracy? Where is D & D located?
Old 07-26-2006, 07:56 PM
Wixom, MI
http://www.ddperformance.com/
Old 08-04-2006, 04:12 AM
Bandit's Avatar
Bandit Bandit is offline
Default Tko 600
TKO 600 all day. Most people I know who have cars with 6-spds (late-model WS6 TA etc.) say they don't use 6th anyway.
You definitely want a manual, for the simple reason that a computer, vacuum or mechanical shifter setup on an auto, no matter how sophisticated, can't read your mind. If you want to control what gear you're in, you can't beat doing the job yourself.
Paul
"Real race cars have 3 pedals"
Old 08-17-2006, 06:36 PM
zcrz zcrz is offline
Default Tko
Seems okay to me so far, nice tranny.
Old 08-25-2006, 08:06 PM
sbbuick sbbuick is offline
How about a Richmond 5 or 6 speed?
