Old 08-29-2006, 04:15 AM
ProTouring442's Avatar
Big spacers will be needed, but they would be the bolt-on type so I wouldn't worry about that. As for the mini-tub, I don't know. It's been too long since I was under a '64-'65 Chevelle.
Shiny Side Up!
Bill
'72 442 "Inamorata"
Old 08-29-2006, 06:57 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
'64-65s are pretty limited for room in the rear... I'm not sure how much space there is, but you may find what you're looking for in one of the sticky topics here: http://www.chevelles.com/forums/forumdisplay.php?f=17
Old 08-29-2006, 08:29 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
The Z06 wheels are going to have what they call an HPO ( high positive offset ) center. If you bolted them straight up... they would be completely sucked under the car and may look a little on the retarded side. I personally do not like using a spacer to accomplish the extra spacing you will need to take up. You are essentially adding additional leverage to your lugs and depending on the quality of the spacer or adapter... you could also have balance or tolerance problems.
Old 08-29-2006, 09:17 AM
93Polo 93Polo is offline
Some have used adapters in place of spacers to run Corvette wheels on A-bodies
http://www.chevelles.com/forums/showthread.php?t=32049
Lamar
69 Camaro RS traded
70 Chevelle SS 396
93 PoloGreen C4 LT1/ZF6 gone
00 FRC C5 436rwhp/415rwtq ported 5.3 heads/cam, MovIt Brembo Big Reds, 04 Z06 suspension
Old 08-29-2006, 06:11 PM
TonyG TonyG is offline
well, seems that dream was shattered quickly. Found out that his Dad is getting the wheels for his 65 Vette I think... I may try to find another set. The idea caught my attention and the more I think about it the more I like it.
Old 08-29-2006, 08:12 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
Even if the wheel offset on them would work,they are too wide to fit under a 64-65 without major mods. IIRC,the fronts are 17x9.5 and the rears are 18x10.5.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 08-29-2006, 08:27 PM
Thanks Clint, I wasn't sure of the widths but thought both were too wide no matter the offset.
