Go Back   Lateral-g Forums > Classifieds > What's it Worth
Old 11-25-2014, 08:19 AM
SSLance's Avatar
SSLance SSLance is offline
They are pricey, especially in that kind of condition. 20k seems to be a minimum and very well could be worth more than that.
Has it been restored or just well kept?
The auto trans and incorrect tires affect it some, but still a very nice piece.
Lance
Old 11-25-2014, 08:26 AM
Sieg's Avatar
Sieg Sieg is offline
I don't know a lot of specifics but I think it's had a jaded life, 3 owner vehicle IIRCC. Don't think it's seen a formal restoration of any type other than a paint job.
The auto may hurt the purist but the swap could be considered ahead of it's time based on current 4x4 trends.
Old 11-25-2014, 02:36 PM
DBasher's Avatar
DBasher DBasher is offline
As it sits I'd say mid teens if it's really that clean. Pull all the goofy stuff off and return it back to OEM and you'd likely see mid twenties.
Stock painted grill
Steelies with poverty caps
Stock exhaust tips
OEM door panels
Power steering and power disc brakes add quite a bit of value to these older rigs, that and they're just more fun to drive.
Old 11-25-2014, 07:42 PM
Wow that thing is nice ! They don't go cheap for sure.
Old 11-25-2014, 10:56 PM
TAC TAC is offline
Nice looking Bronco. Biggest problem with these things is rust. Door posts are a bad area for rust along with floors and quarters.. Its listed as a 71 but its a 67 or 68 by some details on the body and the 289 engine listed in the build sheet. Auto trans were only offered from 73 and up, although the Stroppe Broncos had them in 72. These things go for $20000-$30000 for decent clean trucks. Stock or custom doesn't seem to make much difference. A friend of mine just sold his custom one for $60000. There was a similar one for sale on craigslist here in the Vancouver area a short time ago for $23500
I remember the days when you could get one of these for under a grand and have a good driver........damn I'm getting old.
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
Old 11-26-2014, 07:36 PM
hp2 hp2 is offline
I'd second this opinion and this is an unrestored original. These first gen (66-77) Broncos are a major HOT commodity with off roaders. So much so that Dynacorn is repopping them. That's right, repop Broncos are just as popular as repop Chevelles. Go spot check ebay. Some are upwards of $30k.
Old 12-11-2014, 02:42 AM
Sieg's Avatar
I received more info on this last night and edited the original post to reflect that it is a 1969 with 3 spd column shift. It now has the proper wheels and hubcaps installed. One floor pan was replaced, pretty sure it was the drivers side.
$30K is the number they are thinking. Is that realistic?
Old 12-11-2014, 05:32 AM
SSLance's Avatar
Looks to me now that I review the pics again that there are two shifters on the floor, a manual trans shifter and the one that I originally thought was an auto trans shifter but is more likely the transfer case shifter.
Did they swap this trans shifter out for a three on the tree shifter after the pics were taken?
Regardless, 30k is the upper end...but it might get there. Quite the cult following for that model, especially unmolested.
Lance
Old 12-11-2014, 02:00 PM
Sieg's Avatar
My understanding is the T-handle is the factory transfer case shifter. That's what threw me too when first looking as I could see the column shifter without looking real close........which I didn't.
Here's two pics from today:
Old 12-11-2014, 03:52 PM
DBasher's Avatar
It looks so much better with the painted grill and wheel/tire combo! The first set of pics do show a floor shifter, they probably removed it and went back to the column....so now you've got a hole under the carpet. In the new pics you can see the column shifter through the window, it's either in reverse or 2nd
For 30k, which means 24k, it's got to be as clean as it looks. If it's at a lot you know they didn't pay or give any more than...what? 12-15k?
Sieg, are you looking to buy or just know of it?
