Old 11-30-2014, 09:24 AM
markss28 markss28 is offline
Originally Posted by Rod P View Post
ummm OK...you do know I work for RideTech....
Yea I kinda thought u did.
Still they didn't recommend anything when I ordered. I'll call on Monday to make sure tho. I know u stated 700lb on a leaf spring car but what rate for a 2nd with coilovers on all 4? I'll be changing over to the 4 link in a few months.
Never Stay Stock
Old 11-30-2014, 11:53 AM
Rod P's Avatar
Rod P Rod P is offline
700 front, and when you go 4-link I would do 225 rear .......ride quality comes from the shock settings...I suggest the 700lb springs because it will require less preload on the spring, therefore less coil bind, more travel, better handling
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-30-2014, 06:56 PM
[thread jack on]
That's a great action picture of you and the car, Rod.
[/thread jack not on]
Old 11-30-2014, 08:44 PM
what are your current vehicle weights?
. All will be calculated with vehicle weight. A 3000 lbs car will take less than a 4000 lbs car. It's all a package. As you know. Then there is chassis stiffness and sway bars.
[thread jack on]
[/thread jack off]
. Haa Haa trey, you said... Never mind.
