Old 01-04-2015, 03:26 PM
Ernie W Ernie W is offline
Default Question about CPP C5 uprights for 1970-81 F-body
Hi. I'm new here, mostly just read on the forum. I'm building a 1980 Pontiac Firebird with a 6.0L LS 6-speed. I'm fixing to pull the subframe to do some metal work on the firewall area. I'm looking to do some small suspension and brake work. I also have solid bushings and subframe connectors.
With the brakes, I plan on running C5 front and 98-02 Camaro rear disc setup. Are the CPP C5 uprights a decent piece? Or should I keep walking and go with the Kore 3 hub setup on a modified spindle? I'll be using GM rotors and calipers purchased new thru the shop I work at. Just looking for some feedback on the CPP parts.
Thanks,
Eric
