Old 01-13-2015, 06:05 AM
grendel grendel is offline
Yesterday Scott amused himself by making blocks...
Blocks that got welded into the rockers and the place formerly known as rear frame rails. This gives a solid mounting point for the sub frame tie ins and the new rear frame rails that will need to be dissected to fit the IRS.
Stay tuned for the next episode of "As the wire spool turns".
it's always a pivotal time in a project or even mini-project, when you stop cutting and start adding.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 01-13-2015, 01:18 PM
They definitely look beefy enough.
Old 01-14-2015, 11:19 AM
Giffin sent pics of the reciprocating assembly for the "rpm" motor. They are so very pretty.
68 GMC C1500
73 Camaro
Old 01-14-2015, 03:35 PM
Since we posted the engine porn shots, Scott felt he had to one up Giffin.
The IRS is in and level... if it passes a few expert looks, it will get gusseted and burnt in. It's using DSI bushings to mount the factory sub frame to the new mount points Scott welded in. Certainly not for the weak hearted.
68 GMC C1500
73 Camaro
Old 01-21-2015, 12:33 PM
Since I am going through Camaro update withdrawals, Giff thought he'd cheer me up.
The block's ready to receive the internals and it's getting it's first coat of paint. I also got in the shaft mount lightweight rockers for it, so will run those up shortly.
68 GMC C1500
73 Camaro
Old 01-27-2015, 03:26 PM
Scott's making progress on the IRS. I will order rims soon.
Meanwhile, there's 29.5" of snow here... over the last 24 hours.
68 GMC C1500
73 Camaro
Old 01-27-2015, 05:52 PM
You got to love New England!
Old 01-28-2015, 03:20 PM
bsharpe bsharpe is offline
I vote for flares. I think you can get the spectre flares from Cambell Auto.
Old 01-29-2015, 03:21 PM
If I did flares, they would have to be complete. Those look like they only cover the top of the tire. I like the roadster shop ones.
68 GMC C1500
73 Camaro
Old 01-30-2015, 04:10 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
The Roadster shop says they still have all the molds, just order up a whole body kit!
No Shop, No Money, No Time.... No problem!
